Chev 383 stroker engine 360 rwhp - Beyond.ca - Car Forums
Results 1 to 7 of 7
Thread: Chev 383 stroker engine 360 rwhp
    BoostLand
    something green
    Default Chev 383 stroker engine 360 rwhp
    A friend of mine is selling his motor
    Its a 383 small block stroker, done with all the best parts
    currently the motor is apart for inspection, we were gonna make some internal changes(cam) but then the decision was made to step up to a big block, so here is your chance to buy a 383 with only 5000 km's on it, that made 360 rwhp through a 4l60e which is a power thirsty tranny, so I presume about 450 flywheel hp.. the engine is setup with holley 950 efi, the dyno runs can be verified at Concept-1, it was tuned there by me. This engine has over 10,000.00s in it, not including the labour or the EFI, and we have all the receipts for the stuf
    The parts list is as follows:
    210 afr heads
    high nickle block
    alum water pump
    alum valve covers
    double roller chain
    roller cam
    roller lifters
    milodon 1.5 roller rockers
    hardened pushrods
    H-beam steel rods
    Srp forged piston
    scat 3.75 steel crank
    Moroso pan and pickup
    Moroso oil pump
    msd distr and wires
    fluid damper balancer
    race bolt kit
    all neccesary gaskets for reassembly
    engine has moly rings, and race bearing package
    Super comp coated headers
    5500.00 for the motor
    With Holley commander EFI -pretuned for this motor 7500.00 obo
    We also have:
    2 Msd 6al's 270.00 each
    one old style 6a 150.00
    8 28 lb injectors 225.00
    8 30 lb injecots 250.00
    Too loud for Aspen
    BoostLand
    something green
    Too loud for Aspen
    BoostLand
    something green
    Too loud for Aspen
    BoostLand
    something green
    Too loud for Aspen
    May 2003
    will it fit in an 89 GMC Sierra shortbox?
    2018 Ford F150 SCREW
    yes
    Jun 2003
    1994 Dinan 325is
    PM'd you
  1. FS: 1989 Chev Silverado with 383 stroker
    By Lococoin in forum Cars, Trucks, Motorbikes, and Trailers
    Latest Threads: 11-05-2009, 11:38 PM
  2. 885 RWHP Blowen Viper Dyno Vid
    By SinisterProbeGt in forum Cars, Bikes, Machines
    Latest Threads: 12-06-2003, 01:02 PM
  3. prices on a 383 and a 350
    By )v(ortal in forum Performance Modifications
    Latest Threads: 09-12-2003, 09:31 AM
  4. Crower Stroker Kits
    By Ekliptix in forum Performance Modifications
    Latest Threads: 03-18-2003, 05:28 PM
  5. Juiced Mustang bows to the 383
    By Gripenfelter in forum Street Encounters
    Latest Threads: 02-14-2003, 07:59 PM
