A friend of mine is selling his motor
Its a 383 small block stroker, done with all the best parts
currently the motor is apart for inspection, we were gonna make some internal changes(cam) but then the decision was made to step up to a big block, so here is your chance to buy a 383 with only 5000 km's on it, that made 360 rwhp through a 4l60e which is a power thirsty tranny, so I presume about 450 flywheel hp.. the engine is setup with holley 950 efi, the dyno runs can be verified at Concept-1, it was tuned there by me. This engine has over 10,000.00s in it, not including the labour or the EFI, and we have all the receipts for the stuf
The parts list is as follows:
210 afr heads
high nickle block
alum water pump
alum valve covers
double roller chain
roller cam
roller lifters
milodon 1.5 roller rockers
hardened pushrods
H-beam steel rods
Srp forged piston
scat 3.75 steel crank
Moroso pan and pickup
Moroso oil pump
msd distr and wires
fluid damper balancer
race bolt kit
all neccesary gaskets for reassembly
engine has moly rings, and race bearing package
Super comp coated headers
5500.00 for the motor
With Holley commander EFI -pretuned for this motor 7500.00 obo
We also have:
2 Msd 6al's 270.00 each
one old style 6a 150.00
8 28 lb injectors 225.00
8 30 lb injecots 250.00
