sprinkler system winterization? - Page 2 - Beyond.ca - Car Forums
Page 2 of 2 FirstFirst 1 2
Results 21 to 34 of 34
Thread: sprinkler system winterization?
  1. #21
    Dec 2009
    Calgary/ALTA
    Originally posted by Tik-Tok
    I just hook my compressor to a fitting I installed in the supply line, manually open all the valves, and let it run for a few minutes.
    Paying $75 is ridiculous, lol. It isn't like you need to get ALL the water out of the line, so long as the lines aren't completely filled, then the expansion from the water freezing isn't going to burst anything.
    Agreed on the cost, in fact you can justify to get compressor based on 3-5 years payout just for using it for sprinkler system winterization, and in terms of hookup, I used washer connector to make this hose.
  2. #22
    calgary AB
    toyota MR2
    how big is your guys' compressor (CFM)? and what psi do you set it at?
  3. #23
    Originally posted by adam c
  4. #24
    Only 15min from Aspen!
    Nothing interesting anymore
    8.5cfm, and I keep the psi low, around 40, so I don't wreck the valves.
  5. #25
    Fiesta ST
    I'd say tank size matters more than CFM in this case. I have a 5 Gallon, I run it at 60 PSI until the air pressure is around 40, then I shut the valve and let pressure build up fully to 125 again and repeat.
  6. #26
    Just a tip, that brass air hose/hose bib fitting is sold at Hobo Camper Country on Edmonton trail for $9.95 if you don't feel like putting together your own from parts.
    look, if you stick your dick on my shoulder, then I'm gonna stick my dick on your shoulder. That's how shoulder dicks work.
  7. #27
  8. #28
    Nowhere
  9. #29
    Huh, now I wonder if it'll work on my sprinkler. I need it for the RV too, so at least I'm sure it'll work on that.
  10. #30
    Not Aspen
    Two from Freemont
    so I have been paying $75 - $150 every year to blow mine out. the guy comes with a compressor trailer. Its fucking huge!. Can these little shit compressors do the job?
    So 40-50 psi? I don't want to fuck up my system.
  11. #31
  12. #32
    Not Aspen
    Two from Freemont
    Originally posted by Cos
    click for larger version
    So I know I need this fitting (female) as mine is connected to my water supply inside. It then has a spout like a normal water hose fitting on the outside before dropping into the ground.
    Where do I get it? Or do I piece it together like Sugar?
  13. #33
    Nowhere
  14. #34
  1. LF: Deck Expansion and Lawn Sprinkler System
    By jdmsource in forum Home and Garden
    Latest Threads: 05-22-2015, 10:06 AM
  2. Underground Sprinkler System
    By visualk in forum Home and Garden
    Latest Threads: 04-09-2010, 06:08 PM
  3. Wanted: Great deal on residential sprinkler system repair
    By pei_boy in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 06-01-2009, 03:38 PM
  4. residential sprinkler system
    By grideTLS in forum General
    Latest Threads: 03-03-2009, 07:47 AM
  5. smoking and sprinkler systems
    By 5abi in forum General
    Latest Threads: 12-18-2005, 12:59 PM
