Looking for a really good dumb bell work out. Just picked up a set of powerblocks (50lbs) to save room at home and want to get a complete workout routine going 3-4 days a week.
I dunno
Chest - Flat DB Press, Flat DB Flys, Incline DB Press, Incline DB Flys, if you can Decline DB Press, Decline DB Flys
Biceps - Concentration Curls, Incline Curls
Tricept - Behind your head thing, bent over arm extension
Back - Krok rows, flat rows, crappy deadlifts, the one where you lay down and extend your arms and bring the weight back over your head
Shoudlers - Shoulder press, bent over flys, arm lift things, front arm lift things, whatever when you just pull it up infront of you hand together
Legs - Weight lunges
I also found if you substitute the bench for an excercise ball (when you can), it helps with stabalizing muscles.Originally posted by schocker
I dunno
ie:
What else do you have at home?
Do you have a bench? If so, is it a flat bench or is it adjustable?
man makers
Yes I have a flat adjustable bench. Other then that not much, just resistance bands.Originally posted by A790
You can use that bench for a lot of things:Originally posted by chathamf
Upper:
Dumbell bench
Pec flies
Incline pec flies
Incline dumbbell press:
Incline dumbbell curls
Bent dumbbell row
Dumbbell shoulder press
Isolation curl
Lateral side raise
Horitzontal dumbbell row
Seated overhead tricep extension
Reverse dumbbell curls
Lower:
Cardio training (jump over bench side to side)
Dumbbell step ups
Dummbell dead lifts
Dumbbell squats
Dumbbell lunges
Back:
Dumbell deadlift
Bent dumbbell row
Reverse flies
To name a few.
Thanks guys! Should be able to throw something decent together.
Originally posted by ExtraSlow
Bulgarian split squats.
Originally posted by austic
man makers
If you only have DBs master these
IG:scboss
