hrmmm i cant find the washer pump on my 92 cavalier....any suggestions??
thanks for the replies
Lyle
Lyle
It tough to get to. you have to remove the washer bottle. You should be able to see the connector from behind the headlight. I will snap a pic if you need it.
Are you sure the motor is toast??
in the washer tank i would think
Rev high, ride low.
I've done it enough times on a 89 Pontiac 6000, should be the same engine and all. You need to drain the washer fluid reservoir and then take it out and the pump is attatched to the bottom of it. Its actually quite easy to do.
omgwtfbbq
