1994 Acura Integra Turbo'd, 5 speed, 4 door sedan. I have had it for about 11 years and replaced pretty well every part on the car. I've spend over 30k into it and just use it as a summer car but now I have other priorities and its time to let it go. It is a fast sleeper car, works and handles great and has a nice exaust sound. Very fun to drive and built to perform. Here is a list of parts it has. Serious inquiries only. $7900 obo
link to kijiji with pics
http://calgary.kijiji.ca/c-ViewAd?Ad...5-bb1cfffdc67d
Exterior:
Paint job
American Racing Wheels
205/45/16 Tires New
Interior:
Boost/vac gauge
Egt gauge
Egt gauge sensor
Apexi SafcII
Oil pressure gauge
Glowing pedals
Stereo:
Panasonic CD deck
Power wires
2 pioneer 6.5” speakers
2 tweeters
2 6x9” speakers
Wired up for a 4-channel amp to run all speakers
Driveline:
Energy suspension master bushing kit
Energy suspension motor mounts
Magnaflow muffler
Vibrant muffler tips
3” exaust
3” catalitic converter and resonator
Strut tower bars
ACT xtreme clutch
Tokico HP struts & lowering springs
Engine and Accessories
B18B turbo’d engine
Dart B18 block
Skunk2 cam gears
Skunk2 valve springs
Fearra stainless valves
Eagle connecting rods
Wisco 8.5:1 comp. Pistons
Piston oilers
Commetic head gasket
Apr head studs
Water pump
Gready timing belt
Gasket set
Bearings
Engine installed at 185,000km
Turbo kit
Master power T3/T04E turbo
Inline pro manifold
2.5” downpipe
Greedy type S blow off valve
Tial 38mm wastegate
Drag intercooler
Drag piping
RC550 injectors
Walbro 255gph fuel pump
Drag air filter kit
Accessories
B&M fuel pressure regulator
AEM map sensor
Crome tuned ecu
Heat wrap on manifold
Optional AEM EMS for $1000
New Parts
Power steering rack
Alternator
Radiator
Clutch cylinders
Battery
Trailing arm
Upper control arm
Lower control arm
Front stabilizer arm
Ball joints
Brakes
Spark plugs
10.3mm Spark plug wires
Hornet alarm
Undercoating
Fuel & brake lines
Wiper motor
Tie rod ends
Wheel bearings
Alignment
CV axels
Gas tank
Window regulator assembly
Brake cylinder
