I'm looking for a highly recommend shop that can fix my mistakes or maybe even rebuild my engine project.
Short Story....
2 years ago I decided to put a BT kit from pag parts on my 2000 Audi TT with a 1.8T ATC switched to wideband. I had the motor pulled and put in new pistons and rods to support the new turbo. After precise engine builders bored the block and refreshed the head, my mechanic put the motor back together. I know he's not an engine builder, so I don't know if everything was done right. It's can be driven but something is definitely wrong. I've got about 10,000km on the new build and I'm burning quite a bit of oil (prob 1L per 4K), the idle fluctuates and I can't boost past 8psi (sounds like a leak).
Anybody you recommend that can properly fix or rebuild and not empty the bank? Possibly someone that can also tune a car.......currently running Eurodyne but plan on upgrading to maestro if someone can tune it.
