condensate problem from ceiling - Beyond.ca - Car Forums
Results 1 to 20 of 30
Thread: condensate problem from ceiling
    Oct 2008
    calgary/ab
    Default condensation problem from ceiling
    Hi Beyonders;
    we constantly have condensation water leaking from ceiling during cold and warm weather switching.
    the house builder has spent three years and installed many new style ventilation. but the condensate water problem is still exist. could you guys recommend any condensate engineer/specialist in Calgary to help us?
    many thanks
    Dec 2006
    Lease
    Do you have humidity really high in the house? Lots of members in household taking showers (and not leaving exhaust fan on long enough with bathroom doors shut?)...
    Sorry to hear that, update the thread what happens. It's a topic most Canadian homeowners deal with. (not entirely leaky ceiling, but humidity/moisture buildup around windows, etc...)
    Sep 2005
    What floor is this happening on?
    Far too little detail:
    - is the attic insulation sufficient? (assuming top floor)
    - has a leaking pipe/pipe condensation been ruled out?
    - do you have a hygrometer in the house?
    Oct 2008
    calgary/ab
    it is not water leaking for sure.
    it happens on top floor within bed rooms not in bathroom. I don't know if the attic insulation is sufficient . could you recommend a company who is specialized in this matter of condensate?
    thank you
    Nov 2004
    14frs,06Tacoma,69Olds Vista Cruiser, 73VWwestfalia
    I also suggest blowing more insulation in. I would imagine an attic insulation company would know about ceiling condensation.
    Red Deer, AB
    Sounds like a combination of poor attic insulation combined with higher than usual humidity levels in your home.
    Have you been up into the attic to check the area where you are seeing the condensation on the underside?
    You might have a bare spot in between the trusses that is allowing that super cold attic air to significantly cool off that section of your ceiling... and your warm & humid house air is meeting that surface... that's all it takes.
    Only 15min from Aspen!
    Nothing interesting anymore
    Could also be something as simple as your bathroom fan duct fell off the vent.
    Sep 2005
    2011 lexus is250 awd
    I had the same problem in the first year of owning my home.
    Turns out it was wind washing which is the insulation being blow to one side of the house in the attic. Sterling came in and ended up putting in 10 more bags of the loose insulation in the attic and I havent had an issue since.
    again, far too little information:
    - is it happening every 12-16" along the ceiling?
    - is it happening in every bedroom?
    - is it happening near a window?
    - is there a bathroom nearby?
    Nov 2003
    Many people have this problem and its mostly due to humidity in the house.
    Easy first steps:
    - Turn down the whole house humidifier
    - Run your bathroom fans while showering and for 15-20mins after
    Things to check:
    1) Make sure all the ducting from the bathroom fans is actually hooked up and exhausting out the roof vents.
    2) Make sure all your attic hatches have weather stripping to seal them
    3) Any extra moist air leaking into the attic through lights / fixtures / holes in the ceiling.
    Even with the perfect amount of attic insulation and venting, you will get frost and condensation problems, if you have too much humid air leaking into the cold space.
    Oct 2008
    calgary/ab
    thank you for all the reply. FYI, our house has the flat roof .
    we are now suspecting insufficient insulation now . could you please recommend a company who is able to inspect insulation problem?
    Jul 2006
    FJR1300/2018 Giant Trance 3
    I used Zerodraft when I did my attic. Chose cellulose blown in, and they did a great job fixing up all the ventilation/sealing. They solved my frosting issue on the inside of the roof that I had, and the house holds heat/cool much better now. If I recall, it was about $1k for the job.
    It appears they specialize in what you're looking at.
    http://zerodraftcalgary.com/resident...e-damp-issues/
    Nov 2003
    I also have recently used Enda from Zerodraft, with blown in Insulation.
    $1300 for my place. (~2200sqr ft, 2x attic spaces)
    Oct 2008
    calgary/ab
    thank you all . will contact Zerodraft tomorrow
    Apr 2005
    Airdrie
    You should probably tell them that you have a Condensation problem not Condensate.
    I have been getting something similar where when it warm up quickly outside, or when it is super cold out and I have a hot shower, water will drip down from the ensuite bathroom fan. It was coincidental that we has the roof replaced in early december so I thought it was being caused maybe by the area around the new shingles and the vent having some kind of leak, but apparently when the guy came out to check it all out, they figure it is because the venting into my attic from outside was mostly covered up by insulation not allowing the attic to vent properly causing a build up of condensation. We also had a new humidifier installed just before winter and now we think we may have had it set a bit too high...
    Does this sound like it could potentially be the issue? Sorry for the hijack...
    Not Aspen
    Two from Freemont
    Your humidifier setting needs to change based on the outside temp. The colder it is, the lower you want it.
    Jul 2006
    Why?
    The SHBARUS
    True for condensation around windows, leaking/condensation from the ceiling is on a whole different level.
  1. Idle problem, starting problem. KA24DE problem.
    By vancouvergold in forum Nissan 240sx / Silvia Owners
    Latest Threads: 03-08-2009, 07:27 PM
  2. need help with ceiling fan wiring problem
    By nonlinear in forum General
    Latest Threads: 09-29-2008, 02:03 PM
  3. WTB in-wall/in-ceiling speakers
    By Thaco in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 01-10-2007, 05:46 PM
  4. BMW Orange Glow From Ceiling
    By Clanche in forum Alberta BMW Owners Club
    Latest Threads: 04-09-2006, 02:03 PM
