Vey sweet monitor.....I have a new monitor coming right away...Thats the only reason I am selling......I want $375...comes with box, cd etc etc.....
Specifications:
17” Viewable area
Flat panel display/TFT active matrix - desktop
Depth: 8.7" (22 cm)
Antiglare with hard-coating 3H
Height: 18.1" (45.85 cm)
Weight: 18.5lbs (8.4 Kg)
Width: 17.3" (44 cm)
Color Support: 24-bit (16.7M colors)
Compliant Standards: FCC-B, EPA Energy Star
Dimensions (WxDxH): 17.3" x 8.7" x 18.1"
Dot Pitch: 0.264 mm pixel pitch
Image Brightness: 250 CD/m² typical, 200 CD/m² minimum
Image Contrast Ratio: 500 to 1 typical, 400 to 1 minimum
Image Type: Non-interlaced
Max Resolution: 1280 x 1024 at 60 Hz
Max Sync Rate (V x H): 76 Hz x 80 KHz Port(s) / Connector(s) Required: 15 pin D-Sub, DVI-D
Power: 90 to 264 VAC/50 or 60 Hz +- 3 Hz
Power Consumption Operational: 40 W (maximum); 34 W (typical)
Power Consumption Operational ( Standby : < 5 W
Voltage Required: 90 to 264 VAC/50 or 60 Hz
Serial # 2BQDC9W
This monitor has a DVI input and VGA input. VGA cable is included.
