Anyone use a Mityvac for oil changes? - Beyond.ca - Car Forums
Results 1 to 20 of 25
Thread: Anyone use a Mityvac for oil changes?
    Aug 2008
    Beyond Fit Golf R and Berta RAM 1500
    Default Anyone use a Mityvac for oil changes?
    Was wondering if anyone uses a Mityvac to do their oil changes? Seems like a really nice tool for easy oil changes if you have a top mount oil filter.
    This is it:
    MV7201 Fluid Evacuator Plus
    About $100 bucks online.
    http://www.amazon.com/MityVac-MV7201.../dp/B0054146BE
    Jul 2006
    I have used one of these before. It works pretty well, but I no longer have a car that has an easy to access oil filter.
    They sell this unit at Princess Auto: http://www.princessauto.com/pal/Funn...ctor/8051633.p
    It is slightly cheaper than the one you have posted and it will work.
    Nov 2006
    Edmonton, AB
    not a mityvac but a generic fluid extractor. works great since i only change the filter every other change (as per acura's service schedule). you can probably do an oil change in 15 minutes.
    i have pulled the drain plug to see how much was left after extraction and it was very little in terms of flow, maybe 20-30mL.
    Sep 2011
    So with these fluid extractors do you pump from the top?
    Do they pick up any sediments/metals in the oil?
    EM1FTW's Avatar
    EM1FTW is offline I'm a fag because only fags love Hondas
    Sep 2008
    Calgary Alberta
    EM1 yo!
    These are standard practice for Mercedes, works very well!!
    Originally posted by ZorroAMG
    Kinda like this morning when I wanted to tell my GF to pass the sugar and it came out "You fucking bitch, you've ruined my life."
    Jul 2006
    They do. One thing I've found is that the shape of the oil pan has an impact on the efficacy of the fluid extractor. If the tube can't reach into the corners and such, there will be more oil left in the pan. I've used one on an E90 335 and a mini with no problems/ complaints.
    Dec 2004
    1917 Model T, VW Baja, '18 Ram 2500 CTD/6spd
    Yep, I had to buy one when I had a Merc S500 and it worked great. I didn't trust it at first so I extracted the oil, then went to the trouble of pulling the belly pan and draining the sump just to be sure, and no oil drained from the pan bolt at all. I suppose it would depend on the shape of the pan and where the tube lands though.
    Jun 2004
    Calgar3h
    S14|TB1
    We used a similar sump extractor at the stealership for most of the used german stuff, used it myself on an E39, really good investment with a top mounted oil filter as said.
    Aug 2008
    Nice I'm gonna buy it.
    May 2010
    Vettel's #1
    Vettel's #1
    Just curious, why is this better than just removing the drain bolt? Why does a top mount filter make it any different?
    Vettel's #1
    Aug 2008
    Originally posted by CapnCrunch
    Just curious, why is this better than Juda removing the drain bolt? Why does a top mount filter make it any different?
    If I use a mityvac it makes the job cleaner faster and safer. I don't have to jack up the car ever because my filter is top mounted.
    Dec 2004
    Many modern cars have aerodynamic belly pans that make changing the oil from underneath a real PITA.
    Aug 2008
    My old G35 had seriously about 25-30 bolts for the splash shield lol. PITA
    May 2010
    Vettel's #1
    Vettel's #1
    Jesus, lol.
    Vettel's #1
    May 2009
    G37X
    Bumping this up. Looking at getting one but just wondering a couple things. Do these work by feeding the hose down into the oil pan and sucking through there, or sucking up vacuuming it up through the dipstick leaving the filler cap open to allow air in to replace the oil being sucked up? Also I imagine they'll work with any car pretty much?
    Fiesta ST
    Smallest tube fits inside the dipstick tube and you crack the filler cap open to allow air in.
    Sep 2008
    Turbo stuff
    If you feel like doing a 2 hour oil change. Those things are slow as shit.
    Aug 2008
    I bought mine. Gonna try it out maybe next week. Il see how it goes.
    Aug 2010
    Calgay
    Can also get a version that connects to a compressor
    Euro
    May 2009
    G37X
    Bumping with my experience. Went out and bought this one from Princess Auto for $70 http://www.princessauto.com/pal/en/F...ctor/8051633.p
    Took about 10 minutes to drain the oil and left under half a quart of oil in the pan. Was quite nice being able to not climb under the car to change my oil for sure.
  1. FS: Mityvac 7201 Fluid Evacuator Plus
    By J.M. in forum Automotive Parts
    Latest Threads: 07-24-2014, 12:01 PM
  2. FS: MityVac Fluid Extractor MV7201
    By Pollywog in forum Automotive Parts
    Latest Threads: 03-16-2010, 10:51 AM
  3. What kind of Oil and oil filter does everyone use??
    By Speed_Dreams in forum General Car/Bike Talk
    Latest Threads: 06-16-2003, 11:36 PM
  4. synthetic motor oil. how long between changes?
    By 2000impreza in forum General Car/Bike Talk
    Latest Threads: 07-18-2002, 08:25 AM
