It worked, solved the muting issue.
Originally posted by BokCh0y
How did the firmware upgrade work, issues resolved? And is that for the ojocam2?
Thx.
Thx.
Guys, can anyone explain this lane detection thing to me? I went into setup and I thought I needed to line the yellow up with the red LOL then as I'm driving it was beeping an alarm off at me every time I turned hahaha...
Realized then - it's a lane detection. LDWS or something like that? I should fix it.
Also, I had some footage today and noted the GPS only logged half the trip. Once I hit a certain distance from where I calibrated it - it just stopped logging my location/ speed! I think I need to calibrate again to fix.
Liking it so far though! The software is super awesome. What is the best way to render videos incorporating this software GPS + Speedo ??
Will try reformatting. I am using the Samsung card I ordered with it.Originally posted by BokCh0y
i have had something similar happen, and yes a reboot always fixes it. Mine was an issue with the card. These devices seem to be picky with the type of card you use. Alternative is to format the card and chuck it back in. That usually resolves my issues.
[url]
sorry i have never used the lane detection, but as for the gps software, the only way i found to export the gps info in to a video was to run a screen capture program while i played the video on my pc.. not exactly elegant but it did the job.Originally posted by Kijho
User title molested by Rage2.
GPS hardly works for me and the DataKam Player
The clip will have zero GPS information logged for like, 75% of my trip. Then randomly is starts logging and GPS will begin randomly at a certain point of my travels. This also affects the speed logging etc. I updated the Firmware from the dropbox but no luck.
Also, this is just f*cking typical for me... I've owned my new car 3 weeks and got a rock chip few days back. Today it splintered and a crack formed right across the viewing angle of my dashcam. Wonderful right? I go into DataKam and hit x64 playback and I can f*cking SEE the crack GROWING!!! CalAlta windshield is closed Sunday so can't get it filled until Monday!! Ughhhh...
Originally posted by adam c
Line goes up, line goes down, line does squiggly things and fucks Alberta"The stone age didn't end because we ran out of stones"
OjoCam time-lapse of a wonderful rock chip on my new Subi - Only had er' for 3 weeks.
Also - first day owning the Ojocam too! Now my dashcam spot has this wonderful crack right in the middle.
Sorry I didn't notice your first post. I have a '11 Subaru, and I hardwired it. Was easy to thread the wire down to the fuse box.Originally posted by Kijho
And I feel your pain...I got my first rock chip when my car was only 2 weeks old. I was SO pissed!
I've been having lots of issues with my cam that I bought as a mini 0803. Biggest issue is that it stops recording and shuts off. I use a samsung 32gb class 10 card and it freezes to a point where I can't even reboot it so I have to unplug it and let the battery die. I tried another class 4 card and it's a bit better cause it will just turn off. A reformat will only fix it until the card fills up again and I've done a firmware upgrade as well. I've reset the unit to factory and same issue and I format the cards with the camera and not my pc. Anyone else have these issues? This cam shares one cig cable and I use a splitter that goes to a garmin GPS and this camera. Could power be an issue? I'm almost tempted to replace it with a G1W cause I have two of them and they have been rock solid and I only bought the mini 0803 because of the size for travelling in rental cars.
Are you supposed to use a Class 4 card? I thought Class 10?
I've been noticing this problem with mine as well. I noticed that it does stop recording randomly and then when the chimes again, it starts recording again.Originally posted by Cos
Do you guys have it where randomly I will get the chime like it is starting? I start the car, it kicks on, start driving. After about 5-7 minutes after it has been running it makes the turning on chime again. Not sure what the chime is for, if it is full, actually restarting, or what.
there are a lot of knockoffs of mini 0803, i have a couple myself, and some of them are complete trash, which is why i suggest buying direct from ojocam, then you know you're getting a stable variant.Originally posted by botox
^^ I'm pretty sure this one is real. I did a lot of research for the fake models and im pretty confident mine is real cause all physical features, gps, video software and playback and other software features check out. Anyhow, I've been doing some tests and I think it is a power issue because i use a splitter running off of one cig adapter. I don't have a meter to check but I've had the camera running by itself at home for over 24hrs now and no issues. I'm going to change the cig adapter fuse then add the proper inline fuses to the splitter cable and hopefully that will fix the problem.
Having some issues lately, bumping this thread up. OjoCam Pro 2 isn't recording any audio/ sound anymore.. randomly. Tried reformatting the card twice, still nothing.
It also will randomly skip and not record things, like yesterday it recorded the first 6 minutes of my drive - the next 6 minutes are gone, and then I have another clip for 3 minutes while missing everything inbetween.
I did have a few issues with mine, it would powercycle and stop/start recoridng randomly, i formatted the memory card several times, in the end it turned out to be the memory card, swapped it for another card and its been rock solid again.
That said my go-to now is this guy here, i like how discreet it is and its priced really well, i have one in my truck, and although the truck is only used for a few thousand k/yr for camping, its been fine for the past season.
http://www.aliexpress.com/w/wholesal...n&isFreeShip=y
I've recently been looking at this one too, i like the smartphone connectivity.. havn't seen any reviews though
http://www.aliexpress.com/item/ROCK-...2-527af8a43aa4
Lol, I found it... I had audio muted. You just press the "up" button once! Audio back on!
yeah that was going to be my suggestion until you said it was random, so i assumed that was not the case, glad you figured it out anyway.Originally posted by Kijho
is there going to be another group buy soon?
Originally posted by beyond_ban
Are you looking for a happy ending?? If so, PM me...
