Cut & Polish - Beyond.ca - Car Forums
Results 1 to 14 of 14
Thread: Cut & Polish
    Sep 2003
    996 911 Turbo
    Default Cut & Polish
    Just wondering if anyone here has had a cut and polish done. Any reccomendations? How much should a good job cost on a 2dr hatchback?
    Jul 2003
    Lifted 4.0L H.O.
    it's called a cut polish. what they do is remove a thin layer of your existing paint. it is quite pricey as there is a lot of labor involved. you can probably bet on around 250 dollars. but it is well worth it as it will dramatically improve the look of your paint, especially if it is oxidized!!
    Rev high, ride low.
    Jul 2003
    Lifted 4.0L H.O.
    Rev high, ride low.
    Turbo Supra
    You can do this yourself... i works wonders on faded paint... go to canadian tire and buy a 1500 grit cut polish then just rub it on (vigorously) with a cloth... Lots of sore forearms! I think it cost like 6 bucks or so.
    Jul 2003
    Screamin' Paintworks
    QX80,SL600, Utopia 205SE
    Do not try it if you have to ask how to do it.
    Just get a professional to do it.
    Wetsanding and polishing properly is not a job for beginners.
    Sep 2003
    996 911 Turbo
    Thanks guys. I know how its done but don't think I want to try it and ruin anything. I would gladly part with $250 for a professional job. Its not for oxidized paint, I want to get the clearcoat done. Its got like 10 years of scratches and stuff. The paint is still pretty good underneath.
    Sep 2003
    996 911 Turbo
    I think you've got some sort of wax process confused. I don't think you wet sand vigoursly with a cloth!
    So has anybody had it done here in cowtown?? Any recommendations??
    04 CL9
    does a cut polish get rid or sun swirls?
    Jun 2003
    Canada
    GMC Sierra
    Yes it can
    Maximus
    I can do a good job for you if you want. I have some good 3m products. Pm me if your interested
    HK->Lethbridge->HK
    The Bus
    well, i used to work at a detailing shop. We used a lot of that stuff. I would say its not a beginers job. The rpm of the buffer and shit like that could really ruin your paint.
    They used something call the diamond cut polish, which is really rough and thick. Use a little bit of it on small area at a time, buff out the scratches. then switch the pad, apply a thick coat of polish on it. after polishing apply the sealent to take away the swirl marks and so the polish doesn't oxydize as quickly.
    i've heard of the wet sandpaper trick too but never tried it.
    Jun 2003
    Canada
    GMC Sierra
    Wetsanding can be a little tricky on some colours. 3m has a great heavy cutting compound, similiar to wetsanding, but doesn't scratch as much as wetsanding. I can get great results from using 3M heavy cut, then 3M Paint Sealant.
    get it done proper if you're not sure... it can make your paint look freakin sweet, especially if you've had a repaint.
    a cut polish on a repaint is only needed if you want show quality. the 3m product line is great I used to use it at hallmark autobody. Great stuff!!!!! Hallamrk has a package for a cut polish go to hallmarkautobody.com or just go down and talk to the guys and see what they charge. it might be less that 250 like I said. just throwing rough numbers
    '07 Ranger FX4 Level II
    for a a quck polish job you are looking around 250-300$ for a decent job. For a full wet sand and polish... i would say 500 or more. Give you an idea... i just spent 7 1/2 hours today wetsanding and polshing a black hood on a truck, and the last two days wetsanding and polshing a hard tonneau cover (black also).. so its not to cheep
    Originally posted by rage2
    Just because you're older... doesn't mean you need older women. Nothing wrong with an 18 year old here and there!
  1. FS: OPI & Nicole Nail Polish
    By Ed the SOHC in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 10-22-2003, 01:21 PM
  2. power polish
    By moose_8 in forum General Car/Bike Talk
    Latest Threads: 08-24-2003, 07:08 PM
  3. Cut & Polish
    By SinisterProbeGt in forum Performance Modifications
    Latest Threads: 07-01-2003, 07:45 PM
  4. Port And Polish Intake Mani
    By Ben in forum Performance Modifications
    Latest Threads: 11-15-2002, 05:53 PM
  5. Port And Polish On Your Own
    By ConVict in forum General Car/Bike Talk
    Latest Threads: 10-09-2002, 12:31 PM
