Toyota/Lexus Air Suspension Problems - Beyond.ca - Car Forums
Results 1 to 13 of 13
Thread: Toyota/Lexus Air Suspension Problems
    Feb 2005
    Default Toyota/Lexus Air Suspension Problems
    Nowhere
    My stock air ride experience was with a Ford. Be very careful. I recall one coming into the repair bay, jacked up on one side and the bag let go. The car slammed on the ground and it sounded like someone detonated a bomb.
    Don't want to see someone get hurt by a bag blowing up.
    Jul 2007
    I believe OP's only solution might be height sensors - from what I know any other 'workaround' will not allow air suspension controllers to work properly and even if ride height can be manipulated to look normal, the ride quality will be crap - i.e. you will be bouncing around everywhere.
    I know this doesn't help but I consistently see an older Touareg parked in Sundance area with front left jacked all the way dow and back right all the way up lol Looks ridiculous. I'm sure those things can be very expensive to fix.
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    if you can reach the lines in the trunk you can purge from there... not sure if you cant get to the front ones though or just the rear. i know for fact this works on first gen LS for the rears... its just a press fitting. no tools needed.
    Aug 2008
    USE20
    Nvm...
    ^Beat me to it already.
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    Originally posted by Ymerej472008
    One of my friends with an LS430, who is also a member on here had this exact same problem, if I remember correctly he just drove around on it and it eventually sat back down. Ercchry is his name.
    that was the aftermarket controller being a bitch... lots of screwing with settings for it to figure its shit out.
    a fun 4 cylinder
    What kind of car is it? Pm me I can give you advice
    Most of the systems you cannot bypass. It's better to fix the issue.
    Aug 2003
    1989 MA70, 2006 UZN215
    What kind of vehicle is this OP?
    a fun 4 cylinder
    It's a Lexus RX330
    Feb 2005
    Jun 2006
    My air system on my 4Runner shit the bed a few years ago. Took it to Innovative Autoworx, cause I knew they did a lot of custom air ride work. I got the air lines to the bags disconnected and hooked up to a Tee fitting and then run out to a schrader valve (tire valves basically) mounted beside the trailer electrical outlet. Could adjust the height just by using a regular tire compressor. Was quoted 3 hours to do the job, they had me out in under 1.5 hours with a bill of $130 including some new fittings. Worked great for 2 years, especially when towing (could adjust the rear height to compensate for tongue weight) until I decided to re-do my entire suspension on the vehicle and I threw in lift springs to replace the bags.
    Toyota wanted something like $700 for new sensors and install to fix the malfunctioning system.
    Feb 2005
  1. Replies: 4
    Latest Threads: 02-11-2013, 03:13 PM
  2. WTB: toyota supra/lexus sc300 suspension parts
    By euro_racer in forum Automotive Parts [Suspension/Handling]
    Latest Threads: 02-16-2006, 06:57 PM
