My car wouldn't start last night - Beyond.ca - Car Forums
Results 1 to 20 of 25
Thread: My car wouldn't start last night
    Nov 2005
    2015 Hyundai Veloster
    Default My car wouldn't start last night
    Here are the exact steps which took place:
    - I drove pretty far within Calgary to my friend's house and parked my car in his driveway. Nothing electrical was left on.
    - I was in his house less than 30 minutes.
    - I came out of his house and tapped my Compustar remote, my siren chirped, it dearmed and my pager beeped. The doors had unlocked.
    - I got in the car, turned the key, nothing happened. Absolutely nothing happened, it was silence. No lights on the dash, no radio, no beeps, no clicking, nothing.
    - I tried it a few more times, same thing.
    - I tried putting the electric window down, it went down no problem, normal speed. I do have the windows wired directly into the fuse box, no relay, so they work when the car is off. Been working fine this way for 4 years.
    - He has a steep driveway so I let it roll onto the street so I could start it on the clutch but it didn't catch.
    - I pushed the hazard light button but nothing happened, they didn't come on.
    - He pulled his car out and we hooked up the jumper cables but the same thing, nothing happened. I still didn't have any radio, no lights and it wouldn't start.
    - I touched the cables together to make sure there was battery power, it made a big spark. We have power.
    - We pushed it up a steep hill about 50 metres up, then I tried to start it on the clutch 3 times on the way down, it wouldn't work. I've done this many times in the past, not sure why it wouldn't work this time.
    - I let it coast back to his driveway where I got halfway up his driveway and ran out of momentum.
    - I instinctly hit the hazards again since I was sticking into the road and surprisingly now they were working. I turned the key and it started up no problem.
    What could be dying on it? Starter? Battery? Alternator?
    It's a 2005 Honda Civic with an Optima Yellow Top battery.
    Originally posted by Go4Long
    Originally posted by blitz
    Jan 2009
    South of Glenmore Trail :P
    Depends on the day
    It could be a wiring problem due to the Compustar
    Unemployment Line
    Sierra, RDX
    Loose connection somewhere near the battery?
    Aug 2004
    N/A V8, TTV6, DOHC N/A V6
    Push the clutch in harder. That switch is likely getting worn.
    If it happens again try to put the clutch through the firewall. It'll start.
    -H.P. Lovecraft
    Sep 2006
    Clutch kill-switch should just prevent starting, not prevent ALL electric from coming on, shouldn't it?
    Only 15min from Aspen!
    Nothing interesting anymore
    He's getting no power even in "accessory", so not likely
    More likely.
    Jul 2008
    Moncton, NB
    1989 JDM SW20, 2013 Civic LX 5Spd
    Similar issue on my mr2 this summer. Would start from time to time and other times I'd get sweet f all
    Loose connection at the battery. Main line was good. Smaller wire was brittle at the end. I'd say give that a close look.
    Nov 2005
    Maybe but that was installed 9 years ago. And the brain was replaced after it died maybe 2 years ago.
    Ahh, thought it was the vehicle from your computstar thread. In that case probably a bad ground.
    Jun 2006
    I have a feeling it has something to do with the wiring that was done for your windows. Go back and recheck the work that was done in the fusebox. It's amazing what kind of nest jobs people pull off with wiring when they get their fingers into those places.
    Aug 2004
    Truth. Carry on nothing to see here lol.
    -H.P. Lovecraft
    2010 frontier pro-4x
    Any corrosion on the positive terminal?
    Aug 2003
    1989 MA70, 2006 UZN215
    Dec 2004
    YYC and YVR
    THIS.
    Or your roommate moved back is fucking with you.
    Generally alarms dont interfere with accessory mode. I could see a no-start condition happening (turn key and no crank) but the dash lights, ECU, etc should power on regardless if the alarm is malfunctioning.
    Did you check the fuses? (first thing I always check after the battery).
    Feb 2005
    Canada
    Ummm, test your battery and alternator?
    Nov 2005
    I don't quite have much time to diagnose the issues until this weekend but here are today's symptoms. I will start taking advice posted in this thread over the weekend.
    - Got into car at 7:30am, dome light came on when I opened the door.
    - Tried to start car
    - 2 clicks, all lights went off
    - I jiggled around the wiring on the battery terminals
    - car started no problem
    - drove to coffee shop, drove back home, drove to work, drove home, back to work, back home again. Car started all day without problems.
    Oct 2002
    05 GDB V.8 / ZX10R / T1-7L
    Defenitely loose, or corroded battery terminals, battery wires, or grounding point.
    Bad negative battery cables are common on your year of honda, but given your symptoms, I would say its just a loose or corroded terminal.
    The windows worked because of the lack of amp draw, those motors can pull as little
    as 2amps depending on the manufacturer, one the key was turned to acc, or run, the amp draw was too great due to the resistance at the fault, and will make it seem like there is no power.
    post pics of battery!
    Aug 2010
    E93 335is, F32 435xi, '16 Denali 1500
    Same issue on my Honda remove battery terminals clean them and check all wires to terminals one of mine was internally broken I stripped it and re did the connecter and trouble free since
    Nov 2005
    Even if it's common, I replaced the battery with an Optima Yellow Top so I no longer have the factory battery terminals.
    The windows worked because they're wired directly to the battery, they don't use the factory wiring at all. I understand that now though it was confusing me before.
  1. Why wouldn't I want to buy an F650?
    By M.alex in forum General Car/Bike Talk
    Latest Threads: 09-09-2010, 11:00 AM
  2. Why I wouldn't buy a 3G device on telus
    By scat19 in forum Computers, Consoles, and other Electronics
    Latest Threads: 12-02-2009, 11:14 AM
  3. "I thought you wouldn't mind if I had AIDS"
    By suen_boi in forum General
    Latest Threads: 08-20-2009, 09:48 AM
  4. Replies: 11
    Latest Threads: 06-17-2008, 10:31 PM
  5. Replies: 8
    Latest Threads: 10-05-2007, 04:21 PM
