I recently took my car in for regular maintenance and a brake service and fluid replacement.
I was called by the service advisor and he said my front brake pads needed to be changed. I told him go ahead and now looking at my invoice, I am seeing the following.
Brake Service + fluid replacement- $199
service all physical brake components including brake rotors, calipers and pads. Remove all rust and brake dust build up and lubricate applicable shim kits and sliders. Also perform any adjustments if needed
purge all brake fluid from systems, clean brake fluid reservior and refill system. please bleed out any and all air from system and road test.
Replace front brake pads + machine rotors - $278 labour
Replace front braike pads and machine rotors. Perform full brake service on the front brakes only. clean and lubricate all physical brake parts pertaining to front pads replacement.
Brake Pad set - $124.61
Shim Kit - 52.00
total: 454.61 for bake changing + 199 for the service and fluid replacement
seemed like i got hosed, perhaps someone in the industry can chime in?
