Honda TPMS Programming - Page 2 - Beyond.ca - Car Forums
Page 2 of 2 FirstFirst 1 2
Results 21 to 28 of 28
Thread: Honda TPMS Programming
    Jan 2013
    2014 Lexus IS250
    I had an 08 Accord and the TPMS Self learned within 100km.
    I guess from what everyone says it really depends on the model - but i would try driving a bit and seeing if it resets on its own before dropping $40-$50?
    Aug 2008
    jdm b18c
    100km?!? It usually a trip around the block at 60km/hr, it's not possible and accords do not self learn.
    This.
    Sep 2003
    Calgary // Alberta
    2018 Audi Q5 2.0T - Stage 2 Tuned
    BUMP
    I have a 2015 Honda Odyssey Touring. Does anyone know if the 2015 Touring has auto learning for a 2nd set of TPMS sensors? I have heard conflicting accounts of whether or not the higher ned Ody's have a 2nd ID storage 'spot' or not....
    Jul 2002
    19 Jeep Wrangler, 20 Hyundai Palisade
    Touring will have 2 memory spots for TPMS. Or at least that was true for previous years. 2012+
    Sep 2003
    Calgary // Alberta
    Thanks Aleks - Assuming it has 2 memory spots, does that mean I need to get the new set of TPMS programmed once at the dealer and I should be good go forward to swap wheels myself, or will it auto-learn the 2nd, new set?
    Jul 2002
    That, I'm not sure on.
    Aug 2008
    jdm b18c
    Older touring up to around 2012 did not require programming as they were self initialization, but the newer once all require to be programmed and I don't think you can store two tpms sensors because evertime you program new sensor you are basically deleting the older sensors fcc IDs
  1. FS: 17" 5x114.3 steel rims w/ Honda/Acura TPMS
    By cosmok in forum Automotive Parts [Wheels/Tires]
    Latest Threads: 08-06-2016, 03:10 PM
  2. Extra key wanted for Honda - Programming question
    By LUDELVR in forum In Car Entertainment / Electronics
    Latest Threads: 08-29-2013, 09:47 PM
  3. FS: 2013 Honda CR-V Alloy Wheels w/ TPMS Sensors
    By TL_ in forum Automotive Parts [Wheels/Tires]
    Latest Threads: 01-13-2013, 03:35 PM
  4. TPMS programming for Toyota/Lexus without serial numbers
    By ROBOCOP in forum General Car/Bike Talk
    Latest Threads: 03-30-2012, 12:17 AM
  5. Chevrolet BCM programming / re-programming
    By EternalRage in forum Mechanical
    Latest Threads: 06-08-2008, 09:24 AM
