There are some pretty crazy prices showing from Calgary to a few Southeast Asia hub cities on Delta at the moment.
The cheapest verified prices I've seen so far are...
(roundtrip, including taxes)
Calgary to Singapore (SIN) - $716 CAD
(this is a new record for the cheapest flight I've ever seen from Calgary to Singapore, shattering the old record, set in 2011, by nearly $200)
Calgary to Manila, Philippines (MNL) - $723 CAD
(this is also a new record, shattering the old record from 2011 by $170)
Calgary to Bankgkok, Thailand (BKK) - $825 CAD
(also a new record, besting the $896 flights that showed up in 2011)
How to find and book these flights...
1. Start by searching with Google Flights Explore. Set the destination as 'Southeast Asia' or to one of the three cities listed above (Singapore, Manila, or Bangkok)
Also be sure to set the Trip Length to 10-14 days.
Note that Google Flights Explore displays prices in $USD.
2. Look for cheap date combinations. Write them down.
3. Take those date combinations and the destination involved and enter them into Kayak.
From Kayak, hit the Select button to take you to a place where they can be booked. So far I've had the best luck with clicking through from Kayak to the Delta Airlines website.
You can also try just searching directly on Delta.com, but it's usually easier to use Kayak to play around with date combinations and flight times.
http://www.yycdeals.com/calgary-to-s...ncluding-taxes
