Look for the following:
- Make sure there is a water well with a minimum of 1gpm. If there is a piped water system, it is even better, however it is probably a private utility company. Make sure they are not under Alberta Environment advisory. Most private utility water companies are under advisories since they don't meet the minimum requirements. Not a big deal, but just be aware of it.
- Make sure for any rural properties, you are at the top of the hill. In rural areas there is no stormwater infrastructure (i.e storm pipes) so water will go through your property and in some cases which may lead to flooding.
- Check to see a map where you can see where the drainage goes. This is really important!
- Check with the municipality for any future developments or zoning around the areas.
- Check what type of sanitary system you have. for 20 acres you will have a septic treatment system and field. If you are building new there are new systems in place like advance treatment systems that are highly efficient and they have a smaller septic field foot print. If house is used, check how old the system is and when was the last time the owner maintained it.
- Important to read the title of the property to see what caveats and easements are on the property.
- Make sure there is legal and physical access to the property you are looking at.
That's all I can think of at this time.
KWVII Coilovers||Carbon Fiber Grille||20% Tint||Iforged Daytona||19X8 19X10||RDSport Race Exhaust||Vorsteiner Front Lip||Vorsteiner Rear Diffuser II||GP Thunders 8500K||ACS Roof Spoiler||CF Mirror Covers||
