Floor access panel in basement? - Beyond.ca - Car Forums
Results 1 to 9 of 9
Thread: Floor access panel in basement?
    May 2010
    Calgary,AB
    2015 Kia Forte5 SX
    Default Floor access panel in basement?
    Firstly wtf are these for. I broke the circular panel the other day and underneath was just a bunch of rough concrete.
    secondly, does a hardware store sell a replacement cover or do i need to glue this one back together.
    Not Aspen
    Two from Freemont
    Circular ones are usually for the washroom rough in.
    May 2010
    Calgary,AB
    2015 Kia Forte5 SX
    I got the circular ones everywhere. There are a couple in the place where the washroom should go, two over by the furnace and 2 where i am sitting now next to the electrical panel (5 feet away).
    Quote Originally Posted by BavarianBeast View Post
    Could have been over 60% if I wasn’t a paper hand bitch
    I have a bunch of these as well. Definitely not just in areas for rough-in.
    Cochrane, AB
    Trucks
    You should have one for a clean-out for the main line to the street, also another should have a back flow check valve for the basement washroom rough-in, and possibly another cover with a smaller drain line for a shower/tub rough-in. If you dig through the gravel under any of those covers you will find whatever plumbing is there. The toilet shitter pipe is usually roughed in visible above the slab, but it's possible to also be under a cover.
    May 2010
    Calgary,AB
    2015 Kia Forte5 SX
    ah ok. The gravel seems very concreted together but i didnt try to see if it was loose. There were red sprayed stones in their too.
    Jul 2013
    Calgary / Alberta
    Ya those covers are cheap. I have a couple spares you can have, as I replaced mine with sheet metal and solid wood. Most of my plumbing locations were at the base of my stairs. My plumber bud warned me that they could easily break if someone were to jump on them coming down the stairs. This would be an even worse problem if it was covered by installed carpet. Pm me if you want them, i think they (2of) are around 8" diameter, 3/8 thick and dark coloured plastic.
    Darell is correct.
    It's just hard packed gravel and or sand.
    My plumber once told me that everywhere there is a bend (45*) on the main line, there has to be an access cover for it.
    If there is no rough-in in there for some kind of drain,.. it's likely a bend in the main line underneath all the gravel - about 8-12" below the top of the gravel
  1. Plumbing Access Panel... How to Remove?
    By ipeefreely in forum Home and Garden
    Latest Threads: 04-17-2015, 03:08 PM
  2. Path to Access Walkout Basement?
    By eiysa101 in forum Home and Garden
    Latest Threads: 04-24-2013, 06:42 PM
  3. How can I access a blocked website (access restricted to Japan only)
    By HondaKid in forum Computers, Consoles, and other Electronics
    Latest Threads: 03-04-2010, 03:44 PM
  4. FF: Garage/ Basement/ Concrete floor paint
    By TomcoPDR in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 04-29-2007, 07:17 PM
  5. Replace Civic 96-98 heater control panel with 99-00 panel, need help
    By snow_daniel in forum General Car/Bike Talk
    Latest Threads: 09-07-2006, 12:05 AM
