Monitor - bad EDID fix - Beyond.ca - Car Forums
Results 1 to 6 of 6
Thread: Monitor - bad EDID fix
    Dec 2004
    W204
    Default Monitor - bad EDID fix
    I have an old Westinghouse L2410NM 24" monitor. It's a 1920x1200 PVA screen.
    The problem I am having is that for PC, it has only HDMI and DSUB (VGA). The HDMI connection does not work properly as the monitor reports incorrect EDID info to the computer; the computer thinks it's an HDTV and sends it an HDTV resolution (the odd thing is that I THINK the computer is sending 1920x1200 AND the monitor sees it as such but for some reason it is scaled to possibly 1920x1080). The result is that I get image ghosting, fuzzy text, and a generally washed out picture. This is a known problem with this monitor, and supposedly can be manually fixed:
    http://www.tomshardware.com/forum/25...0nm-hdmi-issue
    But I can't seem to get it to work at all. I've already tried modifying the registry and nothing - same old.
    Really need help here. I am using DSUB now (and yes it works) but I have to constantly re-adjust the display and everything just looks soft.
    I am on Win7-64.
    Jun 2010
    Fixed a similar issue by creating a custom monitor driver with hardcoded resolutions. Was a while ago but iirc used trial of Powerstrip and shoehorned it in, g'luck
    http://msdn.microsoft.com/en-us/libr...(v=vs.85).aspx
    http://www.techrepublic.com/article/...th-powerstrip/
    Different method? http://www.monitortests.com/forum/Th...on-Utility-CRU
    2020 Subaru Forester Sport
    I changed edid before on monitors, let me pull up old info on it.
    EDIT:
    Found the old email I sent to an ebay seller on how to his his monitors. I ordered a dell mini 10 replacement LCD and it had the wrong edis and I was able to fix it.
    I was able to find the forum post that I used to get it all working, I don't recall all I did, but I remember I basically edited the EDID and flashed it in.
    All the info I used to fix my monitor can be found here:
    http://www.wsgf.org/forums/viewtopic.php?f=66&t=19293
    Dec 2004
    W204
    Sweet, thanks for the help! I'll see if I can get anything going.
    Jun 2010
    Hey clem, get this working?
    Dec 2004
    W204
    Ya I got it working - by spending $1,200 on a new monitor LOL.
    No I couldn't get it - but I think in the end, it might actually be a flaw with the monitor itself, not sure. For some reason, through HDMI, the sharpness setting is enabled, but none of the adjustments will allow perfect 1:1. However, reading the comments on other forums, it looks like 1:1 is possible but just not for me. Oh well.
  1. Car selling advice: to fix or not to fix
    By Nickfit in forum General Car/Bike Talk
    Latest Threads: 06-18-2013, 07:46 AM
  2. How to fix a bad sleeping schedule?
    By CUG in forum Health and Fitness
    Latest Threads: 11-27-2010, 10:23 AM
  3. Where to go to fix a bad haircut ... for a dog.
    By BebeAphrodite in forum General
    Latest Threads: 11-27-2005, 11:58 PM
  4. House of Tools=Bad, Bad Customer Service
    By Gazoo in forum General
    Latest Threads: 12-27-2004, 02:09 PM
