Simple Traffic Question - Beyond.ca - Car Forums
Results 1 to 20 of 37
Thread: Simple Traffic Question
    Medicine Hat/Calgary
    toyotas, mitsu, and a ford
    Default Simple Traffic Question
    Heres my mspaint version of the intersection. I am always in lane "B" making a left turn and always get forced into lane 3 by traffic in lane "A".
    This bugs me more than it should but I was taught you have to turn into the nearest available lane which would means "A" turns into 1 and "B" to 2 with no legal way to turn onto lane 3. I'm pretty sure I'm right but yet the only time I see people turn into lane 1 is if they are actually making a left hand turn. I know they could(and should) put markings through the intersection that could legally guide you into lane 2+3 but without any markings are you not required to use lanes 1+2 only?
    Unemployment Line
    Sierra, RDX
    A turns into 1 and B turns into 2. It's not illegal to change lanes in an intersection, but if there was an accident, chances are the police would ticket the person changing lanes.
    Aug 2011
    Strathmore
    2005 Dirtymax
    When A turns into lane 1 like they are supposed to they are to stay in that lane and do a proper shoulder check and then TURN into lane 2 when its clear for them to do so.
    Too many people just turn from A into 2 without looking and cause headaches and accidents.
    There are tooooooooooo many lanes like this and toooooooooooo many people who simply do not abide by the simple traffic rules because it inconvenieces them.
    This is turning NB 14th onto WB 16th. People think you are supposed to turn into the turn lane but when you turn into your proper lane you almost collide with people and get a horn honked at you because again people don't pay attention to lane positioning.
    The SHBARUS
    Be the first then it doesn't matter. If you ain't first, you are last.
    Stampede Central
    is pretty sharp lookin'
    I go B to 3 just to avoid exactly what you're talking about. And if I need to get into 1, then I just gun it in B to beat all the traffic from A wherever they're going.
    Apr 2005
    I'm guessing that the people in A are simply turning too wide (into 2) so B by default has to swing wide into 3 to avoid an accident. The problem is that if someone is coming from the opposite direction to make a right hand turn into 3, then B has nowhere to go. I have a turn like this on the way home every day and it's pretty common for the same thing to happen. In a perfect world I would simply maintain my lane, let A hit me and then they would be at fault. The problem is that it's one thing to be right, it's something else to prove it. A lot of these side-swipe scenarios end up 50/50 because it's almost impossible to prove who was in the wrong lane. And a 50/50 claim does the same thing to your insurance as a full blown at-fault. Solution: drive a 1987 Chevy Suburban and maintain your lane...lol. Nobody's gonna screw with that.
    Next time...
    http://draw.accidentsketch.com/
    Also that 14th N to 16th ave West... I always go into the right lane for turning for this very reason. Also 9/10 times, I will swing it wide and hit the far right lane as to avoid having to honk my horn. Also usually going to Home depot anyways.
    Sep 2006
    Honestly, this is the City's (or whoever's in charge of this shit) fault for not putting a dashed line forcing B into 3 and allowing A into 1 or 2. Forcing cars to turn into a left turn only lane is retarded design and causes a problem where one doesn't need to exist.
    Glenmore WB to Elbow SB was awful for this until they put the line in.
    Default Re: Simple Traffic Question
    You are 100% correct! This is one of those rules to the road that a lot of people either don't understand or just have no idea about, even though it's in the basic drivers handbook. I've actually had some idiot on the inside or first lane honk at me for taking my proper second lane!!!!
    Actually it is illegal to change lanes in an intersection in this case or any other.
    Only 15min from Aspen!
    Nothing interesting anymore
    True, but the dashed lines do nothing to help in winter... or spring, or summer, until they've been repainted in the fall because the winter spraying erased most of it.
    No it isn't. It's bad driving, but not illegal.
    Default Re: Re: Simple Traffic Question
    Keep in mind that if there is a parked car or other obstacle in the first lane around the corner you are turning, then each lane is shifted over one.
    Oh but it is
    Sep 2006
    Fair enough, didn't consider that. I guess signs are a better solution.
    Oh but it is
    No, it isn't. We've gone over this MANY times on Beyond. There is no law in Alberta which prohibits changing lanes in an intersection. If you find one, go ahead and post it up.
    There is a charge for "Dangerous lane change" but it doesn't apply to ALL lane changes in intersections, only ones an officer deems dangerous.
    If 1 is a turn lane, most people will go A -> 2 and B -> 3. Like Mibz says, that's the intention anyways, as all intersections that have the dashed lines will point you into those lanes, since it's rare for any driver to go A -> 1 unless you're doing it to pull a U-turn. Don't think there's anything in the TSA to actually define this particular situation.
    Because the majority of drivers on the road are going A->2 and B->3, if you're in B trying to get into 2, you're probably going to end up in an accident/honked at/evasive maneuver. If I'm in A in the middle of a bunch of cars, I typically just pay attention to what's happening around me and carefully follow the herd. But most of the time, I just take B in these situations just to be safe.
    Grimace
    Yup, I change lanes in an intersection all the time safely.
    Lots of bridges have this lane setup though, and most are dashed as you can't expect someone to turn left and then turn left again and go back in the opposite direction. A good example is nosehill/crowchild or stoney/sarcee. Downtown there is a good one at 4th ave & 8th st SW where there are three turn lanes which go 1>1, 2>2, 3>3 but everyone treats it as 1>2. 2>3, 3>4. People are driving into me every time I turn there, even had somone turn from lane 1 into 3 the other day almost hitting me
    Here is a good example of the dashed line which works great. Never have issues on this intersecton which i use all the time
    https://www.google.ca/maps/@51.08133...3231,95m/data=!3m1!1e3
    Someone can img it if they want im to lazy.
    In this case person in left turning lane has option to go 1 or 2 but second turning lane goes to 3 ( far right lane)
    In Calgary we have enough idiots that the city should do dashed lines for ANY double turn lanes. No one seems to get them.
    I had someone honk at me for turning onto center street into the left lane while they were in the right this morning, apparently all these people need 2 lanes to turn left ffs
    They should make negotiating a double turn lane part of the road test, with an automatic fail for turning into the wrong lane without signalling a change.
    4th Ave and 8th street is a completely different animal. There's lane markings but nobody follows it.
    The biggest problem is that the 3rd lane (the curb lane) on 8th street allows parking for some stupid reason, so if you want to go to Kensington, you need to change lanes immediately after the parked car, make the turn to lane 3 onto 4th Ave to go to Kensington properly. Only problem is, you're not allowed to change into lane 3 at that point haha.
    Whoever made those parking spaces there should be shot.
    May 2010
    Vettel's #1
    Vettel's #1
    I'd just be happy the person in A actually turns instead of trying to go straight. I have this issue on my way home lol. Different intersection obviously.
    Vettel's #1
    Sep 2006
    It happens....
    Yea, this happens at the Crowchild EB -> Nose Hill NB intersection all the time. I need to pull some vids next time I'm there.
  1. Traffic barriers stacked around McKenzie Towne traffic circle
    By Nitro5 in forum Society / Law / Current Events / Politics
    Latest Threads: 09-09-2013, 05:54 PM
  2. WTF is going on with traffic @ the McKenzie Towne traffic circle lately?
    By sillysod in forum Society / Law / Current Events / Politics
    Latest Threads: 06-14-2013, 10:58 AM
  3. FS: Garmin GTM 20 Traffic Receiver with Lifetime Traffic
    By Cueman in forum Automotive Parts [Audio/Video/Radar Systems]
    Latest Threads: 09-09-2009, 09:13 AM
  4. Replies: 16
    Latest Threads: 05-23-2005, 01:51 AM
  5. Simple question!! No smart remarks :P
    By Importz in forum Mechanical
    Latest Threads: 12-11-2002, 11:15 AM
