3/8 torque wrench or 1/2 - Beyond.ca - Car Forums
Results 1 to 5 of 5
Thread: 3/8 torque wrench or 1/2
    Aug 2008
    jdm b18c
    Default 3/8 torque wrench or 1/2
    I'm buying 3/8 Mac torque wrench that is rated for 5-100ft, it does nm,ft/lb,in-lb,kg/cm and degree. Is it possibly to do degree that will probably exceed the 100ft??, let's say your torquing the headbolts and asks for 90degress and 90 degrees again, wouldn't that exceed over 100ft and would that damage the torque wrench? Or should I just go ahead and buy the 1/2 torque wrench?
    Apr 2004
    LX 5.0
    If it asks for 90 degree, then 90 degree again, just use a wrench or ratchet? Or I can lend you a half inch torque wrench...
    Oct 2002
    05 GDB V.8 / ZX10R / T1-7L
    1/2 for head bolts! most times a head bolt will not exceed 80ft/lbs but there are a few that go well into the 140-160 range after market headbolt kits like ARP often go beyond that.
    3/8 torque wrench with angle measurement is more for water pump, intake plenum and upper engine assembly, its definitely used for finer assemblies.
    Also taking a none split beam style torque wrench beyond its rated torque, can permanently damage them, even the new electronic ones with the load cell sensors.
    Aug 2008
    jdm b18c
    I'll just use a ratchet, thanks
    Thanks for the info.
    Mar 2009
    '11 Tundra TRD
    If doing the 90 degrees would exceed the 100ft lb it would damage the torque wrench. I have a Snap-on tech angle and double checked on that as a precaution right away.
  1. Torque Wrench Questions
    By REdOX in forum General Car/Bike Talk
    Latest Threads: 01-15-2008, 03:59 PM
  2. WTB:CHEAP 1/2-in.-Drive Torque Wrench
    By vtec96 in forum Automotive Parts
    Latest Threads: 04-04-2004, 10:50 PM
  3. WTB: torque wrench and tire rack
    By thorin33 in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 11-04-2003, 01:52 PM
  4. Mac Tools 3/8" swivel head torque wrench
    By jaylo in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 01-01-2003, 08:50 PM
