Breaks squeeling on a new car - Beyond.ca - Car Forums
Results 1 to 20 of 24
Thread: Breaks squeeling on a new car
    Oct 2014
    alberta
    Default Breaks squeeling on a new car
    I have a new 2013 volvo s60 and i have my breaks squeeling when going in reverse. My dealership says this isn't something they will fix or warranty even though I've shown them a video on my dash cam to prove the noise.
    Weirdly it only happens in reverse and the colder it is the worst it can be.
    They blame the compounds with the breaks and dirt getting trapped in there. When i had a chance to sit with the mechanic in my car he said if i could narrow it down to which break pad needs replaced he would replace it but the guys behind the desk said they won't.
    Clearly the guys behind the desk don't want to deal with it or have an issue with me but is this something that is typically covered under warranty. Is it worth picking this battle?
    Have you tried re bedding the brakes or taking it to a car wash and giving them a good low pressure spray?
    Alot of high performance brakes just squeel a bit when going slow. Dont know how they are on the S60.
    Only 15min from Aspen!
    Nothing interesting anymore
    Pads/Rotors are never covered under warranty
    Edit: Does the car have hill assist?
    Oct 2014
    alberta
    Ive tried cleaning as best i could but haven't had much luck... I suppose ill need to spend a bit of extra time and give it my full attention.
    Good to know they are never under warranty.. its a bit annoying to have this issue when crappier cars I've owned never had this issue.
    It doesn't have hill assist.
    Crappier cars are less prone due to crappier brakes
    Common complain when moving up to a higher end car actually...
    Oct 2014
    alberta
    HAHA good to know.
    Aug 2012
    Down by the River
    GMC Sierra, LX570
    Key symptoms are low speed (reverse). Just give them a wash, then head out and get them heated up. Probably just deposits left by the pads. My car suffers the same thing when all I do is commute for a week.
    May 2007
    has a stick axle
    Performance / quality brakes are going to make more noise and produce more dust.
    See THIS service bulletin from BMW Canada.
    Feb 2008
    Applewood, Calgary
    1988 300zxt, 90 jetta
    The brakes squeak as you're backing up or when you press the brakes when backing up?
    If you take anything I have to say seriously, you're gunna have a bad time.
    1988 300zxt. gt35, stance coils, etc.
    1990 Jetta VR6 Daily, "stock"
    Originally posted by ercchry
    people are dumb, kids need to stop playing in the streets, SW soccer moms are the worst kind of people, the end
    X5D, Fiesta ST
    Very common especially on higher performance brakes. I have a ton of Cadillac customers that complain of this.
    It's because high end cars typically install bigger brakes than necessary for normal driving. It just means you're not driving it hard enough. Go out at night, back highway, no traffic, drive up to 160, slam on the brakes till you slow to 50. Repeat a few times.
    In the summer I drive/brake hard enough where I get enough wear on the whole system, but it's not easy in winter, so I do these 160 hard braking to get the discs and pads cleaned up, and the squeal goes away for a few weeks.
    Mar 2009
    '18 Murano
    Yep, my CTS did it from day 1.
    Mar 2007
    550i, X5
    This may sound crazy, but it is totally true. I did it in my sti when I would here a noise from the brakes and it worked like a charm. Make sure there is no one behind you haha
    Of course, a perfectly good explanation is boring, so the answer is, it's fucking voodoo.
    Mar 2007
    550i, X5
    The other thing could be a small rock stuck, so try washing them directly like mentioned above. I knew someone with a new Audi A4 that had horrible squealing without any braking applied and it turned out to be a little pebble stuck in there. Good luck to you.
    Feb 2008
    Applewood, Calgary
    The caliper carrier pins on my z rusted solid and wouldn't release tension all the way causing my brakes to squeal when reversing. This is obviously not the problem here.... lol
    Fiesta ST
    My B200 is doing this now, but it's rhythmic so it has to be a spot on one of the discs.
    I'm trading it in next month, so I just turn the stereo up and it goes away.
    Not Aspen
    Two from Freemont
    Actually, Mercedes covers pads and rotors for the first 2 years. Never say never.
    Oct 2002
    335xi 70 c10 84 c10 Indian chief
    its a good thing cause they are like 6 grand
    Nov 2011
    Read this as using reverse, forward would do as well.
    Oct 2014
    alberta
    Yeah when im pressing the breaks... for example when exiting my drive way while breaking. I am on a bit of an incline..
    Sounds pretty common so ill take up the advice of those who posted some ideas for me. Thanks!
  1. Traxxas XO-1 tire SQUEELing realistic sound
    Latest Threads: 09-07-2012, 10:00 AM
  2. Drag racer seat breaks while launching car
    Latest Threads: 10-11-2011, 01:34 PM
  3. Brazil - Coffee breaks, smoke breaks, masterbation breaks
    By D'z Nutz in forum Society / Law / Current Events / Politics
    Latest Threads: 05-15-2011, 10:31 PM
  4. Squeeling sound while driving
    By Destinova403 in forum Mechanical
    Latest Threads: 06-22-2009, 09:54 PM
  5. Squeeling sound when braking
    By nagooro in forum Mechanical
    Latest Threads: 07-30-2007, 09:30 PM
