FS: 1988 Nissan 300zx - Beyond.ca - Car Forums
Results 1 to 2 of 2
Thread: FS: 1988 Nissan 300zx
    Feb 2008
    Applewood, Calgary
    1988 300zxt, 90 jetta
    Default FS: 1988 Nissan 300zx
    Vehicle Details
    Year : 1988
    Make and Model : Nissan 300ZX
    Exterior Color : Maroon
    Interior Color : Black
    Auto or Manual? : 5 Speed manual
    Odometer Reading : 231k
    Location of Vehicle : Calgary
    Description :
    I've owned this car for just under 10 years and have put countless hours of blood sweat and tears into the car. It's time for me to move onto something new and see if someone else wants to enjoy it. I lost count long ago what I have invested into the car, but it's well over $15k over the years.
    Up until recently, the aftermarket support for this chassis had been fairly lacking, so I have custom made numerous parts for it and purchased some as well. Some of the parts include:
    Rod end rear suspension arm setup
    Rod end front tension rods
    Full 3" stainless steel exhaust, v-band joints
    Coilover mounts (now commercially available)
    Full ducting from intercooler to radiator
    Upper intake plenum
    Intercooler piping (blow-thru MAF setup)
    Turbo relocation manifold with external wastegate.
    Fuel pressure regulator mount and various other component mounts
    I swapped the entire interior from bright red to black, including new headliner material and custom wrapped arm rest.
    All maintenance completed in the last few years as well, fresh timing belt/water pump/all seals on front end, brake bleed, transmission and differential gear oil, coolant flush, probably lots I am forgetting.
    Below is a list of parts installed on the car to the best of my memory.
    GT3571 journal bearing turbo, turbine housing ceramic coated.
    3" thick aluminum radiator
    3" thick intercooler
    16 row oil cooler
    42mm turbonetics racegate
    ls1 stainless steel exhaust manifold studs
    P&P heads
    5 angle valve job
    Colt cams 'stage 2' turbo regrinds
    SATAN turbo relocation exhaust manifold
    schneider valve springs
    1 5/8" screamer pipe
    DEI exhaust wrap
    ASCO Solid engine mounts
    Fuel/control:
    Nistune type 1 board
    Greddy profec-b spec 2 boost controller
    Walbro 255lph pump from an s13
    550cc SARD injectors (same as fc turboII)
    A1000-6 FPR
    AN fuel fittings all around
    Billet -6 fuel rails
    Innovate LC-1 wideband w/ G3 afr gauge.
    Brakes/footwork
    Fronts:
    Varrstoen ES 2.2.2
    18x9.5 +12 25mm spacer, effective offset, -13
    Rears:
    18x10.5 +0, no spacers
    Tires:
    Fronts, 225/45/18 Federal 595
    Rears, 245/45/18 Federal 595
    Rod end rear trailing arm setup
    s13 Stance GR+ coilovers
    Serialnine weld-on collars
    custom rear upper and lower coilover mounts
    MSA anti-sway bar endlinks
    Bump-steer spacers on the front
    Prothane total kit polyurethane bushings
    1990 z32 30mm 4 pot iron brake calipers
    z32 front rotors
    s13 to z32 brake lines from PDM
    Replaced one rear caliper, rebuilt the other, new rear pads and rotors.
    Drivetrain:
    Centerforce dual friction clutch, new rear main seal when installed.
    Stock R200 LSD (clutch type) rebuild with 6 clutches (2 stock)
    custom solid rear differential mount
    custom solid rear crossmember mounts
    Polyurethane transmission mount
    Stock FS5R30A transmission (same guts as z32tt transmissions)
    Ebay s13 short shifter, custom heavy shift knob
    Interior:
    Nardi 350mm Deep corn perforated steering wheel (stock installed currently, nardi and quick release hardware will come if the price is right)
    NRG Quick release.
    NRG Hub (s13, still need to purchase at this point)
    Innovate analog AFR gauge
    Autometer gauges all around (boost, oil temp, water temp, oil pressure)
    Ronin Yonaka racing seats, custom mounts
    2 kicker compvr 10" subs
    Oldschool kenwood deck
    oldschool RF amp.
    New black carpet with aluminum foot plate
    Red interior converted to black, every, single, last, piece.
    lo-tek 3 gauge pod
    The car is fully registered and insured in alberta. I have driven the car recently, but don't put a ton of miles on it. I have recently moved to BC. I can have someone show the car to interested parties, but will have to make a trip out to calgary to test drive the car for those that are absolutely serious.
    The car will need a few things to be 100%. It will need a professional alignment, I've got it close with the tape measure method but it should be dialed in by a pro to maximize the car's potential. It could use a professional tune as well. I've given it a good safe basic tune on the road, but again it should see some dyno time to get it dialed. The car could also use new rear subframe bushings, the ones that I installed a number of years ago never fit perfectly and when the suspension loads up in reverse there's an audible clunk from the bushings moving on the mounts. Could also use a height adjustment when doing the alignment, the rears should come up a half inch or so to even everything out. There is rust on the rear 1/4 panels behind the wheels, I have parts to replace this but bodywork scares the pants off me. The paint is in decent condition as well but would do well with a good cut/polish and wax.
    Again, the amount of time, money and effort put into this car is significant. It has been my baby for the better part of 10 years.
    Extras :
    Some miscellaneous maintenance parts
    Extra full set of coilovers (additional $1000)
    Asking Price :
    9000
    Contact Information
    E-Mail : [email protected]
    Phone : four03 nine2three 64ninefive
    Pictures :
    click for larger version
    If you take anything I have to say seriously, you're gunna have a bad time.
    1988 300zxt. gt35, stance coils, etc.
    1990 Jetta VR6 Daily, "stock"
    Originally posted by ercchry
    people are dumb, kids need to stop playing in the streets, SW soccer moms are the worst kind of people, the end
    Feb 2008
    Applewood, Calgary
    Bump, coming back to calgary for the weekend of May 1st-3rd. If there's any interest, that'll be the time to view it. There's a chance I'll be bringing it home with me after that weekend, so if you want it while it's still registered in AB, now is the time.
  1. 1988 Nissan 300zx project
    By DeleriousZ in forum The Garage
    Latest Threads: 04-14-2015, 08:55 AM
  2. 1988 Nissan 300zx Shiro, only 75 in canada
    By six2eight in forum Nissan / Infiniti
    Latest Threads: 08-12-2010, 08:50 PM
  3. FS: 1988 Nissan 300zx Turbo - Project...JWT450Kit and Lots of Mods
    By Commanderwiggin in forum Cars, Trucks, Motorbikes, and Trailers
    Latest Threads: 10-25-2008, 11:02 AM
  4. WTB: 1984-1988 Nissan 300zx
    By simonseys in forum Cars, Trucks, Motorbikes, and Trailers
    Latest Threads: 03-25-2007, 08:04 PM
  5. FS: 1988 nissan 300zx
    By AdamSarkozi in forum Cars, Trucks, Motorbikes, and Trailers
    Latest Threads: 05-25-2004, 12:46 AM
