I currently have 3 1/2 inch snatch block.
I also own a 6 inch snatch block
Now using a snatch block doubles your pulling power....of your winch.
How do I figure out the mathematics on the difference between snatch blocks?
Sometimes you have to take a chance, whether that be on someone, or something!
No diffence - rated to wll on tag. But the 3" would be for a small winch - like 2000lbs - there's a math formula, based on rope diameter to shiv diameter - 3½" would be for ¼" cable or thereabouts, 5/16" like most 8000lb+ would need a 5"+ shiv.
But there is no way to calculate - its on the tag or stamped in. If its not its trash.
I'm not sure about the particulars number wise. However, a heads up. A pulley, or commonly referred "Snatch block" doesn't actually double the winches pulling power. A pulley (Snatch Block) reduces the load the winch thus giving it the mechanical advantage.
It doubles the capacity of your line, or 3x etc. Also reduces stress greatly on winch.
How does a snatch block not double the force applied to the pulled object for a given force exerted by the winch? That's usually referred to as "pulling power".Originally posted by CelicaST-162
Well my RZR pulled out a 5 ton on the weekend stuck in waprious using 2 snatch blocks the rzr tied to a tree. It was crazy to see!!
Friction of the block. Usually times 4% per sheave.Originally posted by BerserkerCatSplat
You should always use the desirable minimum diameter and not the critical minimum when making a pull.
The formula I use for wire rope strength is diameter squared times 40T divided by a safe working factor of 5. Add 10% for wire core.
1/2 x 1/2 x 40 = 10 tons / 5 = 2 tons
