I have a light bar that came with the pre-installed relay. I have it installed with a switch, however find using the switch on top of using the high beams a bit cumbersome, plus I usually only use the light bar if the high beams are on tanyways (not on highways!)
So ideally, I want to be able to have the LED switch on, and LED only come on when I have the high beams on. Or have the high beams on, and LED switch off (i.e., regular highway driving)
Can I do a fuse tap to the high beam fuse where the relay is pulling power from? #30 if I remember right
Thanks
