Originally posted by AE92_TreunoSC
Basically a flood no start both ways. In both scenarios you have to drain the tanks, often by removal. Then cleaning and purging the injectors.
The diesel engine is far worse because you have to bleed the injection system. I've done lots of both and it's a pain. The Duramax isn't as bad others.
Glad the truck is recovered!
Gas in a diesel can dry out some of the seals...
A little bit of diesel in a gas wont be too bad, just a little bit more lubricity , haha... might run a little less smoothly,,,,,usually will still run though
"Speed has never killed anyone, suddenly becoming stationary… That’s what gets you."
