Vehicle Details
1998:
Eagle Talon TSI AWD :
Grey:
Grey Leather :
Manual :
152000 :
Airdrie :
Prothane complete poly bushing kit w/motor mounts
New toe control arms
New front and rear sway bar end links
New Megan racing lowering springs
Walbro 255 fuel pump
Aeromotive fuel regulator
Fuel injector clinic 1150cc injectors
B16g turbo – ported – ceramic coated
Evo exhaust manifold – ported – ceramic coated
O2 housing ported – ceramic coated
Megan racing 3” Down pipe, 3” all the way back
Engine rebuilt, bottom end stock
Balance shaft eliminated
New oil pump
New water pump
HKS Timing belt
ARP head studs
Titanium lifters
Comp cams
Magnus Racing sheet metal Intake manifold
75mm Throttle body
2 oil catch cans set up
Front and rear upper strut bars
Front and rear lower sway bars
Steel braided brake line
New clutch master cylinder
Steel braided clutch line
ACT 2600 clutch
Fidanza flywheel
Mishimoto radiator
JDM intercooler kit
A/C delete
Custom cold air intake w/dejon intake tube.
DSMLink V3 - have sensors installed and cables to run SD but not currently running SD
Short shifter kit, with all bushings
Innovate LC-1 Wide band
Slotted and drilled rotors
New e-brake cables
Bride lowmax racing seat with customized bride seat rail.
95-96 talon twisty side skirts
19” TSW Luguna wheels with Falken Rubber.
There are a few minor things it needs. The camber needs to be adjusted, with the new Megan racing springs when going over large bumps the tires rub. it also needs a new O2 sensor for the INNOVATE wide band. Lastly it needs to be tuned, I installed full version 3 of DSM link but haven't had the time to properly tune it. The price has been adjusted to reflect these needs.
No test pilots! will not sell the car over the phone! only in person.:
$8500 :
Vern 403-818-8233
[email protected]:
http://www.kijiji.ca/v-view-details....dId=1083207458
