Need help cutting two 7" holes in 2mm Plexi-Glass - Beyond.ca - Car Forums
Results 1 to 8 of 8
Thread: Need help cutting two 7" holes in 2mm Plexi-Glass
    May 2004
    Calgary, Canada
    958.2 Cayenne Diesel
    Default Need help cutting two 7" holes in 2mm Plexi-Glass
    Hello All,
    I thought I might be able to do this by hand, but I'd rather not mess it up. Just wondering if there is any place in Calgary that would be able to drill two 7" holes in a piece of Plexi-Glass that I would provide to them (already marked)
    Originally posted by arian_ma
    your stomach is full of sulfuric acid
    May 2004
    Ford, Acura
    Jig saw, cut just inside your line then sand or file smooth.
    I'm generally cute.
    Wouldn't a drill press & a hole saw do a cleaner job? I used to drill holes in Lucite all the time, but I am not sure how similar that is to Plexiglass.
    calgary ab
    4x4
    Router and jig... Hole saws in plexi (especially thin) tend to make it crack.
    May 2004
    Calgary, Canada
    Sorry, I actually have Lucite (acrylic). I thought they were the same thing.
    Thanks for the feedback... now I need to find out where I can try some of this equipment.
    Can't really help but any time I've cut lucite, you need to go slow. It heats up, stinks and starts to melt.
    Yeah if you go too slow, the drill bit can catch and you'll crack it with the torque of the drill. Too fast for too long and you'll melt it. Best way I found was medium-high RPM, and very gradually and lightly drill a tiny bit at a time, backing off every couple seconds for it to cool.
    6.7 CUMMINS, E50 AMG
    depending on how large the piece is I can machine that hole easily and accurately.
    Acylic tends to be very brittle. Jig saw may crack it
  1. FS: Omega Aqua Terra XXL 150m 49.2mm watch
    By gokuu in forum Fashion and Apparel
    Latest Threads: 01-25-2014, 03:55 PM
  2. FS: 10" Plexi Glass Sub Box
    By virusx in forum Automotive Parts [Audio/Video/Radar Systems]
    Latest Threads: 04-16-2008, 11:22 PM
  3. FS- 10" Premier sub W\ Plexi-Glass bandpass box
    By dsol19 in forum Automotive Parts [Audio/Video/Radar Systems]
    Latest Threads: 09-14-2006, 04:09 PM
  4. Plexi Glass
    By Ghettobaby in forum In Car Entertainment / Electronics
    Latest Threads: 09-25-2005, 11:24 PM
  5. where to buy 1/2 inch plexi glass?
    By eblend in forum In Car Entertainment / Electronics
    Latest Threads: 06-22-2005, 08:40 PM
