20b are retarded in price. Like 8k
there's one right now on kijiji.Originally posted by Maxx Mazda
Cosmo with a 20B would be TEH W1N but good luck finding one...
never mind seems to be a 2 rotor still? says twin turbo similar to rx7. sick car none the less.
That one is a 3 rotor 20B (hence why he's offering to buy back the engine) but with that many issues it's a tough sell.
Thats not a 3 rotor. its a 2 rotor. the cosmo came with both. its like the 13b-rew that comes in the rx7...but more power i think. It could be a 3 rotor, but i doubt it at that price. the eunos cosmos came with both.
Ordered some goodies today.
intake port template, MED street port
Exhaust port template, MED street port
bearing tools for doing rotor bearings and main bearings. may as well put this press of mine to use.
Checking rotor housing widths. They allow .0024 total variance, and so far, ive measured .0010 as a max, most are less. They are going off to Freelance Motorsports for a "hone" soon. They wont need much, so thats goood.
Will wait to get my irons lapped until AFTER the porting process.
Should be a fun project. Hope to do rotaries for other people too. So, lets see, so far ive built ca18det, sr20det, rb, 2jz, and now a rotary. FUN STUFF!!! Love learning more.
Paid for my housings to be machined, ship em out next week!
http://www.freelancemotorsports.com/...g-resurfacing/
They do some pretty amazing stuff, good reviews.
Evan how will you perform the port? CNC or hand tools? You should take a little video regardless.
Also, how much of the horsepower equation does the port job control? how much horsepower is that port good for assuming everything else is able to make / supply lets say 1000 hp?
Cnc ftw
CNC Guru*
Instagram: goreski_rdd
Jeremy wants to take a look at if he can tool it to be cut with his cnc. Im more than happy to let him try, but i figure it may come down to hand porting. Its pretty simple actually. Spray tool makers dye around the port, let dry. Put template on port, scribe lines. Hog it out, transition it, smoothe as possible. Rotor housing is the same idea, but you need to keep the sleeve in mind. I gotta research that still.Originally posted by KRyn
Think of the porting on a rotary, more like a cam on a piston engine. By opening up the port, you A- allow more air and fuel in, but also, B-you change the intake event phasing to be earlier. Mine is a fairly mild street port, so it would be like a fairly mild cam. Most guys easily make around 400 hp or so on a street ported 13b with a single. Alot of the guys making 500+ hp seem to be bridge ported. Im not quite ready for a bridge port yet. I want to explore the limits of the mild increase of factory ports.
Nice to see someone using proper porting templates. I know we have a couple professional builders in this province who feel letting a die grinder rattle around in there for awhile will do the trick, but a proper port job will pay off in the end!
Originally posted by Arash Boodagh
Before I start pwning all the members with my findings.Originally posted by Arash Boodagh
Plus, is it true you can feed a pig elephant dong and it will still grow and build meat?
Toma the homophobe?Originally posted by Toma
rx7_turbfoags best friend
yah i wont be doing that kind of garbage work.I take pride in my work. I dont build crap (=Originally posted by rx7_turbo2
I just wish i could do some base lines without the port job, vs the port job, but that would involve tearing it down twice. No thanks (=
Quite possibly, myself and my friend Jeremy here, may get together and get some programming together for a cnc port job. I wonder how many people would want theirs done?
I love goodie days!!!!!
Primary port:
Secondary port:
Cant check out the housing template because they are at Freelance...BOOOO!
I gotta say, these bearing press tools are realllly nice. They give you a sleeve with both. With the sleeve off, you can press the bearing out. With the sleeve on, you can press the bearing in, and it acts as a stop so you cant overpress. Smart cookies!
More to come!
What is the tightest corner radius approximately?
CNC Guru*
Housings just got back from Freelance, and i gotta say, they did a fantastic job. They look 10x better, and they also blast and ultrasonic clean them. For 150$ usd, i cant complain at all.
Before:
And after. I went along both housings with a straight edge and a .002in feeler. I could not get the feeler gauge in ANYWHERE. They are flat as could be. The flash makes the tooling marks show up, but i assure you, they are as smoothe as can be. It only looks rough!
And the exterior condition. VERY clean.
Very pleased with them. There was an issue with shipping, etc, and they took care of it without skipping a beat. Totally recommend these guys for resurfacing housings. Apparently all they remove is .0005 at a time. Very very little.
More to come as i get my side plates lapped. Im currently in the midst of purchasing a new toy, so things may be a bit slow. The "toy" is totally worth it, i will be able to offer something to the community with it.
Decided that porting is a skill that maybe i should learn. I was feeling up to the challenge today and got started. Took me 2 hours to do the first secondary. Gotta get longer grinding stones to reach into the primary port, but i got the aperture done anyways.
Done the aperture on the secondary, still a bit of bowl work to do. Gasket matched the inlet.
Primary aperture marked and taped. As you can see, alot more to take out here.
Template on top of almost finished aperture. I must say, turned out very close. Remainder gets blended with 100 grit stone
Aperture finished, some bowl work done.
Gasket port matching on right, stock on left. Hard to see but i actually took quite a bit out. The port can taper ALOT more from how it is.
More to come, went and got some new grindy tools this evening. back it it tomorrow.
Oh NICE! That's beautiful. Those internals look amazing, what's the eta?
dv/dt
ready for summer i hope.
Scored a link g4 PNP ecu for it as well. Thanks Nguyen@Autodream!
Plans have also changed, single turbo, borg warner SXE362.
So, need turbo, manifold, and clutch still.
My new seat covers i ordered came in. Very nice quality for the price i must say. EXACTLY match the stock stuff.
Oh, and i bought this......... (old picture, but you get the idea, its the dyno)
After a control system upgrade (probably next year) she will be up to date. Great to start out with! I also have the new Link knockbox dual sensor model knock detection ordered. Should have that mid month.Let the fun begin!!
Awesome, just awesome... can't wait to see the rollers spinning
CNC Guru*
You and me both
