So much misinformation! Must resist.... Just a couple points.
I will say one thing - for those of you who think this is a "pipe blowout" you couldn't be more wrong.
These types of leaks happen as a pinhole on a weld, likely on an elbow UNDER insulation. It will drip, then slowly piss and finally "let go" and it won't be larger than say a toonie or if it's a crack a pencil.
Also, it's not like this is a transportation "pipeline". It's a produced fluid return header from the well pads. It has back pressure from the front end treaters and the wells on the back. You do not notice a drop in production header pressure unless it is a true blow out. Such a blow out will never truly happen on the line as pipe leaks don't work like that - unless you have water/steam hammer which you would not within this line. It's always hot normally when the plant is up.
The DCS may or may not have interlocks for ESD's due to a low production header pressure condition. Most likely just an alarm for the control room to investigate and send a field operator to physically look.
What bugs me is the lack of redundancy in their physical checks. They should have the wellhead field operator doing 2-3 well site and line rounds, the team lead should also do this, followed by maintenance EVERY SHIFT. Obviously they didn't, or didn't look to hard.
-H.P. Lovecraft
