P.Eng Application Question - Beyond.ca - Car Forums
Page 1 of 9 1 2 ... LastLast
Results 1 to 20 of 177
Thread: P.Eng Application Question
    Oct 2008
    Default P.Eng Application Question
    Hi everyone,
    I just recently covered 4 years of work experience and believe I'm ready for my P.Eng application.
    That being said, I have one question:
    Does all 4 years of experience have to be under a P.Eng?
    Where I work now, i am not working directly under a P.Eng. I used to be, but the P.Eng that was formerly my lead has left the company. I intend to use the time under him, in my application. However, the rest of the time I was under a non-P.Eng.
    Please shed some light on this situation, and as to what I could do to help my case.
    Thank you.
    Mar 2009
    Silverado
    I wouldnt quote me but as long as you still have access to a p/eng to review your work its all good. They do not need to be your team lead.
    Quote Originally Posted by Gestalt View Post
    Im the one with a learning disability....
    I dont get it. As price goes up, demand goes up?
    Technically the NE
    C63S
    Yea i think a coworker can count as long as they are willing to sign off on your work. It also doesn't have to be a direct report if your bosses boss is an engineer you can also use them.
    Its more important that you were doing real engineering work all 4 years than who you are working for.
    Food Court Wifi
    2010 Recession Fighter LX
    You do not have to report directly to a P.Eng, or in some cases, even have one review your work.
    It's been a few years since I applied, but when I did, I thought this was covered pretty clearly in the application documents. If you have questions, APEGA is actually quite helpful with these things.
    Middle-aged prima donna
    Mar 2010
    Fiesta ST
    I'm in the middle of filling in my PEng application as well. Having issues since the first place I worked out of school has basically disintegrated and I can't track down any of my supervisors/bosses minus one that is still there but he was doing so much shady stuff that I left because of him for ethical reasons. I'm not exactly inclined to phone him up and ask for a reference.
    Nolan
    Mar 2011
    This is correct.
    Vulva S40 T5 AWD
    As long as you have a P. Eng to sign off on all the years, you should be good.
    I had an identical job as a friend of mine, but did not report up through a P. Eng or have a P. Eng mentor at all.
    I got credit for basically 50% of my time. My friend got 100%.
    It took me forever to get mine.
    Mar 2011
    I got 100% credit for work done without a P. Eng. in the company. This was about 9 months ago.
    What was your line of work? They have factors for certain jobs. IE: they may only give 50% for what you did as work.
    Your friend may have written his experience better on the form.
    Mar 2010
    Fiesta ST
    For any of you that did your application, any chance you could PM me a sample of how you explained your experience? I think I've done a good job but would rather this go smoothly than get partial credit for my time
    Nolan
    Jap V8
    Without going into a ton of detail, I spoke with someone at APEGA a couple months back - he told me to cater it towards technical/design experience, not Project Management experience. They really value the technical over the PM stuff, so that will make things go better. Something else he said is include everything you think might make your application stronger (i.e. co-op work, even if it wasn't under a p.eng or if it was before your third year).
    Hope that helps a bit
    Mar 2011
    I essentially did mine in point form:
    - A
    - b
    - c
    Just writing short descriptive examples of what I would do on a day to day basis and how I did things (what formulas I use or methods to figure things out for example).
    I'd send you a sample but I can't seem to find it anymore.
    Food Court Wifi
    By the time I got around to doing mine, I think I had 13 months more experience than the minimum. That probably helped.
    Shouldn't have procrastinated, but at the time, my employer wasn't offering any raise or anything for getting the certification, so I wasn't motivated.
    Mar 2010
    Fiesta ST
    Thanks guys, that helps
    Normally I wouldn't be in a rush as speaking to coworkers they get nada from getting their certification, but the way things are going if our office does layoffs I'd rather be job hunting with a PEng rather than an EIT
    Nolan
    Food Court Wifi
    True story, if you are job hunting, it is a leg up to be a P.Eng. and every little bit helps.
    Jun 2004
    Just for future reference, you don't need to be under a P.Eng for the 4 years, and don't need all 3 references to be P.Eng's. 3 is preferrable, but only 1 is mandatory.
    Oct 2008
    Is this really true? Where did you find this info?
    It would reaally help me out because my current lead that i work under isn't a P.Eng.
    My manager is but he's being a little bitch and won't give me a reference since I haven't worked directly under him.
    I'm in an EPC, and for the most part I've done technical work. It's just matter of finding someone who will give me a good reference....
    Sounds like your manager's a dick lol. If you report up to him with only one lead in between he should be able to verify your experience record. It's not like he had to sign off on everything you've ever prepared. Plus, I've never heard of anyone's references actually getting questioned over the phone. Your references essentially click an online survey with the option 'Yes, I agree that the applicant has accurately described their experience and I recommend them for P.Eng designation.'
    I would suggest listing your current lead as your "Supervisor", and find a more senior P.Eng colleague that is willing and able to be listed as your "Reference" on the experience record. I did that for one of my records where my direct supervisor was not a P.Eng and I had no problems. At an EPC I'm sure there were subject matter experts that you consulted that would vouch for your technical experience, even if they were consultants themselves.
    Mar 2011
    Only require 1 P. Eng Reference. I believe it says so right on the application. I only had 1 on mine.
    Mar 2010
    Fiesta ST
    I have my application active now. It asks for a Supervisor and then there is a place for one Reference as well. There's no room for 3 references (unless you listed them below in the extra space I guess)
    Nolan
    Mar 2011
    If you are using 2 references from the same job you have to make another copy of the page and change the reference... It's stupid.
  1. Facility Eng vs Production Eng
    By cidley69 in forum Careers
    Latest Threads: 08-11-2014, 03:31 PM
  2. APEGA P.Eng Application - clarification
    By outlook in forum Careers
    Latest Threads: 05-27-2013, 07:33 AM
  3. Replies: 3
    Latest Threads: 01-25-2013, 05:58 PM
  4. Replies: 12
    Latest Threads: 09-03-2008, 05:58 AM
  5. Replies: 1
    Latest Threads: 02-28-2008, 08:49 PM
