STI powered EJ257
Background: I bought my 2009 Forester XT Limited in December 2014. July 4th 2015 I was heading to BC on HWY1 and it spun #4 bearing in Kaninaskis Country. $712 to get it towed to Calgary, then got it to Kipp Scott Subaru who pulled it for diagnosis.. pretty bad. Oil pump cavitated and starved the bearings.
I've been posting updates on this build since the 22nd of July on Subaru forums, forgot about dear old Beyond :P I come here to bitch about TWD
July 22nd post:
Today I have ordered an EJ257 shortblock and the whole timing belt system, all the oil parts, and W25 heads with a 2011 STI intake.. next stop, VF48 & STI TMIC
July 27th post:
Yep, another 09 dies from bad bearings. Seems to be a very common failure point in the 09 FXT, 08/09 WRX & STI. I've owned it for 7 months, and its my first Subaru..
Here's half the bearing:
I bought an OEM EJ257 short block from Heuberger Subaru. Hoping for a later model unit. Also everything to replace the oiling & timing systems is coming, gaskets & bolts.
Sourced complete W25 heads (cams, buckets, valves etc) & intake manifold (TGV, injectors, harness, throttle, etc) off a crashed 2011 STI with 15,000 miles.
I gave consideration to a VF52 swap, but would do a bigger IC and needs protune anyway, I may as well put the money towards the STI parts and have the full swap. In the long run it wouldnt save me much.
The Lazymans Signature (tm)
