LF: Garage door repair recommendations - Page 2 - Beyond.ca - Car Forums
Page 2 of 2 FirstFirst 1 2
Results 21 to 28 of 28
Thread: LF: Garage door repair recommendations
    calgary ab
    4x4
    Sorry folks, no door tools really haven't come out in 6 months, very unlikely I'll have time in my schedule for new work. (I work on call 24hrs 5days a week - my 40ish hours off already aren't enough)
    Aug 2016
    M
    Does anyone have any recommendations for garage door repair? Our door usually closes with no problem. However, on very bright sunny days and some cold winter days, it doesn't close. When you press the button to close, it closes a little bit then opens again. And the light attached to the motor flashes a few times when this happens.
    I called Tony @ Best Doors based on a few other threads, he called me back same day and is gonna pop by today for measurements and stuff. Seems nice enough.
    Aug 2016
    M
    Thanks, Mibz.
    Calgary, AB -- Canada
    Are you referring to the LED light on the opener head unit that is flashing? If so, count the number of times it flashes and search for it online. It will help narrow down your search for the problem.
    I helped a buddy diagnose his with very similar problems. The LED code on his Chamberlain was a 4, which means the sensors were misaligned (SOURCE: http://chamberlain.custhelp.com/app/...button-mean%3F)
    The weird thing is that the lights on both sensors were steady and the correct colour.
    Turns out that the spring-type of mount the sensors used would bounce around a bit as the door moved on a slightly misaligned track, causing the sensors to not 'see' each other properly.
    This is the type of mount used:
    click for larger version
    We corrected the track misalignment and snugged up the sensor mount, and it's been working perfectly since.
    Aug 2016
    M
    Thanks, Raceman6135. It is actually the light attached to the motor hanging from the ceiling. The flashing of the light just indicates that the door cannot be closed properly. I did check the light on the sensor, it does not flash at all when opening or closing the door.
    calgary ab
    4x4
    Sunlight can blank em out... Chamberlain sells a fancy cardboard origami shield kit to help if really needed (usually I just swap them side for side)
    The green LED will go on/off - yellow always lit. Bright sunlight at just the right angle, green can appear lit - get closer its actually a ~60hz flicker.
    They have a 20° field of vision - not a laser by any means, eyeball straight 99% of the time will fix it. But if the tracks flopping all over the place - something else needs repair.
    I'm not recommending anyone right now, those I trusted seem to have bailed on the industry as well...
    Aug 2016
    M
    Thanks for the tips, AndyL. I have put a lid of a small box on top of the sensor this morning when the sun was shining (just a little bit) into the garage. It closed ok. Will keep trying for a few more days.
  1. Quiet Garage Door Opener Recommendations?
    By riced in forum Home and Garden
    Latest Threads: 08-07-2022, 06:59 PM
  2. Garage Door repair
    By Kaos in forum General
    Latest Threads: 01-08-2009, 09:00 PM
  3. LF: Garage Door Repair
    By sexualbanana in forum General
    Latest Threads: 12-23-2008, 10:37 PM
  4. Garage door repair
    By bigbadboss101 in forum General
    Latest Threads: 04-28-2008, 08:58 PM
  5. LF: Garage Door Repair ASAP!!
    By pei_boy in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 06-06-2006, 12:07 AM
