Well after passing up on one of these a couple times over the years, never having time for a project car, and never wanting to race my daily driver, I finally pulled the trigger. This first post doesn't actually contain anything interesting so it's safe to stop reading now and wait til I post again.
The goal: Find a cheap ass RX8 with a blown engine, spend the winter fixing it up and go racing in 2016. Rotaries are easy, what's the worst that could happen?
The car: It's a 2005 GT with 89K on the clock and the engine is so blown it won't even run. Check.
First steps.. Well, get it home. Check. And, LOOK HOW HAPPY IT IS!
Now let's tear into it.. The battery is toast, that's easy.. Now it at least cranks. Looks like the thing's been sitting a while.. Bet the fuel has gone bad. Better change it out.
Step one: no drain plug, locate fuel pump. Oh there it is, under the back seat. That's a heck of a lot easier to get to than on my last car where you had to dive in through the trunk. Thanks Mazda!
...Oh. You need a special tool to get the thing out. Thanks Mazda. ಠ_ಠ
The tool costs $25 online? And I have to wait? I don't have time for that! I'm gonna make my own. Now I've been called a lot of things in my years, but 'competent welder' isn't one of them. Oh well. Long as it passes the drop test, I only need it for a day. Stupid welder, setting one isn't hot enough for good penetration, setting 2 blows holes in the surprisingly thin walled tube.
Whatever, here it is. I held my breath while welding the nut.
So it turns out the fuel pump access is actually not at the highest point of the tank. What the fuck? Can't take this off unless you're under 1/2 tank, 1/4 to be safe. Great. Gotta actually use the pump to get a bunch of gas out. Connect hose to outlet, jumper some pins in the fuse box for this exact purpose, let it run. If you're wondering what the hell I jumpered it with, it's copper shavings from my lathe. Don't ask.
Okay, time to use my tool. If you noticed there's more weld on it than the last pic, fuck you I don't want to talk about it.
And there we go! I had to take the pump out on the driver side and some kind of secondary pickup out on the passenger side, then slid a hose in there and sucked it all out.
The one bit of good news is the assembly comes out much easier than other cars I've worked on. You don't have to twist and swear and force the assembly up through the hole.
It's just too bad they used that dumbass ring instead of a few bolts like the rest of the world.
Oh well. That's all for now.. Tank is now bone dry. Next step, yank the engine. I just wanted to start this thread early because I've never actually bothered to log my work before. Within the next couple weeks the engine comes out and the real fun begins.
