battery or alternator? - Beyond.ca - Car Forums
Results 1 to 5 of 5
Thread: battery or alternator?
    Sep 2002
    88 supra turbo
    Default battery or alternator?
    Got a question and hope you guys can help me out!
    how do you know if its you battery or alternator thats needs to be replaced?
    Thanks
    NW
    ACR/EG/FJZ80/DC4/DC2/22RE
    Use/Buy a multimeter and test the battery and then the alternator.
    Battery should be around > ~12.6 volts
    (Car not running)
    Lower and it could mean it's not being charged or the battery is no good.
    Altenator - You need to have the car running to test and see what the output is coming out.
    Vancouver
    take a monkey wrench and put it down on both terminals, hold on tight!
    j/k, DON'T DO THIS!
    If you find that the charge is lower than ~12.6, it could be either, even neither. Check the terminals and see if they're loose or badly corroded, also check the alternator drivebelt and see if its slipping, could also be a short in the wiring or broken wires. Check all of these, measure voltage.
    (maah raahde)
    Why don't you take it to Partsource?? They'll run some tests for you and can tell you whether or not it's your battery. The tests won't cost you a thing to do.
    Aug 2002
    2008 Accent hatch S
    engine not running batt. avg 12.4-13.3 V
    Enging running output should be 13.5-14.7 V
    If below on eather scale you have found which one is wrong. If low on batt. recharge and see if it will hold the charge.
    If low on alternator replace alternator
    OFFICE ARITHMETIC
    Smart boss + smart employee = profit
    Smart boss + dumb employee = production
    Dumb boss + smart employee = promotion
    Dumb boss + dumb employee = overtime
  1. Car Battery Cable...
    By Davan in forum Mechanical
    Latest Threads: 11-06-2002, 11:20 PM
  2. Battery relocation
    By buh_buh in forum General Car/Bike Talk
    Latest Threads: 11-05-2002, 06:38 PM
  3. FS: used car battery
    By 2000impreza in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 10-31-2002, 09:53 AM
  4. Alternator
    By QBA in forum General Car/Bike Talk
    Latest Threads: 09-28-2002, 02:27 PM
  5. Need a battery!!
    By Madmax in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 07-23-2002, 01:39 AM
