Lifted Truck + Slide in Camper Discussion - Beyond.ca - Car Forums
Results 1 to 8 of 8
Thread: Lifted Truck + Slide in Camper Discussion
    Ferrari
    Default Lifted Truck + Slide in Camper Discussion
    Anyone run a lifted truck with a slide in camper? Thoughts? Problems? Observations?
    Life is too short to drive boring cars.
    Well, there are multiple forces at work here. I haven't done this, but I have dealt with slide-in campers.
    Firstly, depending how tall the lift is, you may be at or past the travel of the camper jacks to even get this thing loaded.
    Secondly, many pickups are payload limited in situations like this, remember most camper weights are "dry" weights, and don't include cargo, batteries, water etc. Also trck payload numbers don't include passengers and luggage. Incredibly easy to go past your rating, even with a one ton truck.
    The third thing, and the one that's hardest to solve, is the instability produced from having a heavy weight very high up. Cornering sucks with a camper even at stock height. It will be just that much worse with a lift. You may want to look into suspension upgrades, like thicker sway bars, stiffer springs, or "stable-loads". Air bags help, but only if they are not connected, otherwise they can make things worse around corners as the load shifts.
    Do you already own the truck and the camper? If you like, post the weights.
    Not as big of an issue, but highway fuel economy will be worse, as you are catching more wind.
    Ferrari
    I've got an 06 F350 CC/SB with a 4-6 inch lift and 35's. It's 'average' Alberta diesel size. The previous owner did all the work and it's set up for a camper. Belly bars, air bags and everything. I'm looking at a camper with a 3200lbs dry weight. Not really concerned about the payload too much as I think it's 4000 on this truck not including modifications.
    I'm on factory wheels and my plan was also to get a set of aftermarket wheels with a greater offset, and some fender flares etc. Nothing too crazy just a better look and I think overall the added width of the track will help stability.
    Reason for camper is so I can pull a trailer as well (quads, race car, etc.) and I like campers in general.
    X5D, Fiesta ST
    Why not a camping trailer with toy storage in the rear section and a sled deck for extra toy capacity if needed?
    Feb 2010
    yes
    Default Re: Lifted Truck + Slide in Camper Discussion
    Nice Rob, ha ha.
    Anyway, It's almost certainly doable, and it is handy for pulling a small trailer. Although, I wouldn't be so quick to dismiss the payload concerns.
    Crew cab truck will hold a lot of people or gear, plus the dry weight of the camper, plus the gear in the camper, plus the tonge weight of the trailer. it adds up pretty fast. It's worth your time to run this combination across the CAT scale at the truck stop a couple times to get it set up correctly.
    Also, find out if the air bags are connected together or separate. Makes a big difference to cornering behaviour.
    And, even if you do determine you are within your limits on this setup, the cornering will be pretty poor, please take it easy, don't be Mr. Typical Alberta Diesel guy while you have the camper in the back.
    I love campers too, was practically raised in one, enjoy yourself!
    Ferrari
    Originally posted by ExtraSlow
    Nice Rob, ha ha.
    The air bags arent connected. It has a massive sway bar in the back too, larger than the camper package one I imagine. I drive my truck pretty easy since its a ford I dont want it to break.
    Im not super concerned about the payload because weve had some serious equipment in the back of the truck at the farm and it didnt seem to really affect it too much. Balancing between the axles is another story. Would have been easier had I bought a EC/LB Dually instead of this but I never anticipated a camper 4 years ago.
    I like the ability tow any sort of trailer behind the camper. Race car, horse trailer, etc. We had a regular sort of non toy hauler trailer a couple years ago and it was okay but limited to what you can sorta do or you have to bring multiple vehicles, that sort of thing.
  1. FS: Joey Bed/Slide out Cargo Drawer for pick up truck
    By rinny in forum Automotive Parts
    Latest Threads: 06-01-2013, 09:43 AM
  2. FS: truck and camper
    By MarkFJ40 in forum Trucks, SUVs, Vans, Trailers
    Latest Threads: 06-16-2009, 04:40 PM
  3. FS: Truck and Camper
    Latest Threads: 07-15-2008, 08:53 AM
  4. OOPI On a lifted truck.
    By CSMRX7 in forum Trucks, 4x4 and Offroading Zone
    Latest Threads: 10-25-2006, 08:07 AM
  5. Marker lights on a truck camper mandatory?
    By Alex_FORD in forum General
    Latest Threads: 06-02-2006, 01:26 PM
