Garage containment mats - Beyond.ca - Car Forums
Results 1 to 20 of 29
Thread: Garage containment mats
    Apr 2007
    GLS63 AMG
    Default Garage containment mats
    The issue I had since buying this home with the garage has become significantly worse as the result of the unit heater I installed this summer and I am in the market for a garage containment mat for all the water and snow that drops onto the floor from the vehicle when it is parked.
    I've looked at a couple options thus far and would like anyone who uses any of these mats first hand experience with them.
    The Park Smart Clean Park mat seems to be the most popular but people who have reviewed them say they are crap to install and are of poor quality:
    https://www.homedepot.ca/en/home/p.1000735373.html
    The next one I found was Auto Floor Guard Containment mat, which I can't seem to find any negative reviews of and is the mat I want due to it being wider than most others, I can't seem to find these locally other than
    http://wickedworkshops.ca/auto-floor...ge-floor-mats/
    The next one I found is similar looking to the Auto Floor Guard one but made in Canada I guess?
    http://www.canadamats.ca/garage-containment-mats.html
    2020 Subaru Forester Sport
    Interesting idea, never knew about these. I just use a large squeegee blade broom thing to take all the crap out of the garage, along with a humidity controlled exhaust fan, seems to work alright
    Mar 2005
    Calgary/Alberta
    2022 X2M
    Must Buy.
    I will be hunting for those next week. I have been dealing with a soaking wet garage for two years now.
    E .· ` ' / ·. F
    Your tears fuel me
    Apr 2007
    GLS63 AMG
    I'm afraid a squeegee won't save my drywall as it goes right to the concrete floor and the water runs towards the wall.
    Put in a drain...
    Feb 2010
    yes
    Originally posted by mix123
    Put in a drain...
    how you add a drain to old cement floor?
    Are drains in garages legal in the city?
    Not Aspen
    Two from Freemont
    Yes, I have 2.
    Jul 2006
    FJR1300/2018 Giant Trance 3
    Not Aspen
    Two from Freemont
    You cut it.
    Mar 2010
    Ioniq 5
    My dad got a huge really heavy weight tarp and some 1" wood dowels, wrapped the edges around the dowels and uses that. It contains all the water inside it, then he uses the shop vac to suck up the water if it gets too much.
    Red Deer, Alberta
    1995 WRX STi
    I would think they have to run into the actual waste water lines and not just into the storm drain system.
    Originally posted by codetrap
    You could glue down some channel around the edges of your garage to keep the water from the drywall... or just cut the drywall an inch up from the floor to prevent the wicking...
    This is the best idea, drywall shouldn't touch the garage floor.
    I'm assuming that this is a detached garage (as the footing on a attached garage is usually concrete the first 2 feet up)? Because even if you cut the drywall back, you'll still want to keep the 2x4 studs from getting wet as well.
    Proper ventilation goes along way, it surprises me how few garages have some sort of air return setup so moisture can leave.
    Apr 2007
    GLS63 AMG
    The garage is detached, thanks for the suggestions and all but for the time being I'm just looking to contain the problem as I also wish to preserve the concrete slab from the water/dirt/salt etc and don't pLan on coating yet. I'm guessing none of you guys have used the containment mats, I've read about the improvised ones and would much rather buy one prebuilt, I was just looking to see if anyone had any experience with them.
    May 2009
    Medicine Hat AB
    General Motors Competizione
    My parents have what looks like the third link in your OP. They seem to work.
    2007 GMC 2500 Duramax
    1981 GMC C1500 454
    Feb 2010
    yes
    Originally posted by benyl
    You cut it.
    is it that easy to do in calgary? i know you can cut basement for toilet. that is deep.
    if you cut garage floor like that, then water freezes, and ice causes pushing on concrete? look like big problems. any experts here?
    I've seen it done in 2 Saskatchewan garages. Both were heated. Had a trough the length of the garage cut in by the overhead door then a hole similar to the picture above. Cement poured in and cleaned the trough up. Then put a submersible pump in the hole to pump the water. Your imagination can figure out where it pumps to. I also had one where there was a 3 foot deep pit in the middle of the garage. Similar to the hole above where the water just collected and then I would empty it with a wet vac every so often in the winter. That worked really well actually.
    Ideally a new build with a proper drain is best...but thats not always an option
    If you were building the garage from new, a dry well below the low point that is dug down below the frost line is an option. I have heard of that being done, and apparently works fine for "normal" amounts of water.
    I suspect that's a little more of a pain to retrofit into an existing slab.
    Apr 2007
    GLS63 AMG
    Ordered a 7' 9" x18' Auto Floor Guard mat from wicked workshops, cost $429 shipped, taxes included. They sold out of the 8' 6" ones earlier in the year and said they won't be bringing them in anymore due to the weak dollar.
    Jan 2003
    Very interested as well. Please post a review after you've got yours. Any reason why you didn't go with the third option? Is it because it is beige color?
    Aug 2005
    2007 4Runner
    Here's another brand Tapson that is made in Canada and available here in Calgary.
  1. FS: Rubber Mats 5'x7'- Great for Gyms, Garage, etc
    By iron_man888 in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 04-23-2015, 09:32 PM
  2. FS: 12 HipHop Vinyl Records with Slip Mats Mats
    By mikey_p in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 07-14-2010, 09:10 AM
  3. Cleaning garage! Storage cabinets, tools, steel toe boots, floor mats and more!
    By inline6turbo in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 09-12-2009, 03:10 PM
  4. Garage Mats or the like in Calgary?
    By whitecastle in forum General Car/Bike Talk
    Latest Threads: 01-30-2009, 12:23 AM
  5. One Car Garage vs. Two Car Garage
    By fordo_11 in forum Real Estate / Finance
    Latest Threads: 07-11-2006, 11:52 AM
