Pet door - Beyond.ca - Car Forums
Results 1 to 11 of 11
Thread: Pet door
    Mar 2014
    Default Pet door
    I'm in serious consideration of adapting a puppy. I know they require lots of attention but I know there will be some times will he/she will be home alone for a few hours.
    Is it possible to install a doggy door in an existing glass patio sliding. door? This way if he or she needs to go to the washroom they can.
    G05
    It is possible. Something like this: http://patiopetdoorinc.com/pet-door-details/
    Not sure where you can get it locally though. But a puppy could handle a few hours. Look into crate training or maybe a playpen with a pee pad area as an alternative as I wouldn't want my dog running around the yard free range (when I'm not around at least- he can go run around outside when I'm around). Depending on the type of dog you get, they might be a digger and escape your yard when you aren't around.
    Nov 2004
    edmonton
    Ford
    adopt a full grown, they can hold pee all day.
    my dog pee at 630am before we leave for work. then 4pm when wife returns.
    Street Tune
    446HP 536TQ W/6# Lower, 3.5 upper 16* and 16psi
    Mar 2014
    What would a full grown be considered? I'd like to get one that isn't older than a year
    Aug 2004
    Back in Calgary
    03 Mdx, 05 Gli
    Keep in mind pet doors don't seal very well. We have a hot water boiler system and last winter a pipe near the door froze because of the small draft it was letting in... Obviously shouldn't be a problem with a normal furnace though
    Dec 2011
    I adopted my dog and he was approximately a yearish old. They don't know since he was a rescue with no background. House trained, crate trained, just had to do more training on the side. Best dog I've ever had without the hassle of a puppy. Although he acts like one still (about 3.5 years old now).
    I've had him for two years now, we no longer use the crate, but he stays in my room when I'm not home. I've lost a few articles of clothing do to him chewing, but thats because I didn't burn off his energy and he was bored.
    Mar 2014
    What adaption agency did you use and would you recommend them? I have an interview with pawsitive match tomorrow.
    Dec 2011
    Pawsitive Match was the one. It's a process to get a dog for sure, but worth it.
    There are quite a few around, just hop on the google and check them out. I've heard of people getting dogs from almost every agency. It's nice that you can "trial run" the dog, so to speak. Have the dog over for a couple days to see if you can adjust and if the dog fits in your house, but not so long the dog gets attached
    Dec 2013
    2013 Ford Focus ST
    My husband made a doggie door for our patio doors. He used leftover sheet wood, not thin like plywood and cut a hole in it and installed rubber flaps on the inside and outside. It fits right into the opening and into the track groves. We leave it up all winter and just close the inside door when we are no using it.
    That being said we don't leave it open all day while we are at work cause we don't want her running around the yard. She gets out in the morning when we both get up and then she gets out when I get home at 4pm. She gets a walk right after work as well.
    I leave the doggy door open all evening so she can come and go as she needs/wants. We just put some foam in the crack between the door and wood to seal off the draft.
    As for adoption places, we got ours as a pup from Rocky Mountain Animal Rescue from Canmore. They rescue dogs from Morley and from Mexico. I highly recommend them.
    Feb 2007
    2000 Civic SE
    I went through little mutts to adopt my 10 month old jack russell mix, great experience, the availability of dogs vary due to the "shipments" that they get from the states so if you keep checking it goes from no dogs listed to 15 in a day. I was in the same situation as you - wanted a puppy but didn't have the time/patience to deal with one so I went this route and I couldn't be happier.
    I was able to choose a dog that fit my needs (no barking, crate trained, etc) without having to deal with the surprises a puppy brings (who knows what personality they will have). I also choose the breed of dog because they're smart and fast learners I only had a handfull of accidents within the first month of him learning to sit by the door.
    I was also meeting dogs through pawsitive match and they are great too, very similar experience, I ended up going through little mutts in the end because of the dog that I decided on but I would consider either in the future for my next dog. All of the foster families I met throughout my process were so great and really help you make the decision if the dog is right for you.
    Mar 2009
    '18 Murano
    +1 for Rocky Mountain. We transported 2 dogs from Cabo for them last time we were there. Great organization.
  1. Pet peeves that should be pet peeves
    By speedog in forum General
    Latest Threads: Today, 03:07 PM
  2. Pet Peeves That Shouldn't Be Pet Peeves
    By baygirl in forum General
    Latest Threads: 04-28-2024, 11:27 AM
  3. door frame chinup bar without drilling/harming door frame?
    By wardpr68 in forum Health and Fitness
    Latest Threads: 08-03-2010, 02:40 AM
  4. Replies: 8
    Latest Threads: 12-09-2009, 01:51 AM
  5. Door to Door Saturday morning... lol
    By Genjuro in forum Society / Law / Current Events / Politics
    Latest Threads: 12-05-2006, 06:52 PM
