Sous Vide, who's doing it? - Page 21 - Beyond.ca - Car Forums
Page 21 of 34 FirstFirst ... 11 20 21 22 31 ... LastLast
Results 401 to 420 of 664
Thread: Sous Vide, who's doing it?
  1. #401
    May 2007
    has a stick axle
    I dremeled a hole in a cooler and use that as my container. Huge volume and no water evaporation problems.
    Attachment 83515
    Hey @rage2 is that a Coleman 24 Can Stackable cooler?
    Just did a Prime Rib last week and want to do some ribs this week. A cooler setup would make life much easier.
  2. #402
    '14 Taco
    Quote Originally Posted by KRyn View Post
    thats what i use, it works great. that photo Rage has is the same
  3. #403
    May 2007
    has a stick axle
    What size hole you drill / dremel for use with an Anova?
    Speaking of ribs, what temperature and cook time is everyone using for pork back ribs?
    Last edited by KRyn; 04-11-2019 at 11:18 AM. Reason: Who has suggestions for cooking ribs?
  4. #404
    '14 Taco
    Speaking of ribs, what temperature and cook time is everyone using?
    I took the little thing that hangs on the side of the pot, drew a line around it, and just cut it out with a hand saw. Definitely not as pretty as some, but it works.
    I do ribs around 160 for ~12 to 24. Any higher temp and they fall off before you can finish them on the BBQ. Same with pulled pork.
  5. #405
    Stampede Central
    is pretty sharp lookin'
  6. #406
    May 2007
    has a stick axle
    Thank you!
  7. #407
    Nov 2009
    2016 Tacoma TRD, 87 944 turbo, 06 DL1000
    Got this cooler a couple of year ago and did a similar thing but I split the lid in 2 so I can check on things during long cooks without having to remove the Anova
  8. #408
    '14 Taco
    Quote Originally Posted by Vdubbin View Post
    thats super smart, as some of the meats start to float if they're fattier or let out air depending on spices, etc and you dont really want to cook for 24 hours with half the thing outa water
  9. #409
    Nov 2009
    Ya I find Pork really back for doing that. I usually have to re-vacuum and seal it on multi-day cooks. But even with the cut in the lid I can run multi-day cooks and only lose about 1/4 inch of water.
  10. #410
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    If you cut the hole to hold the bracket and do it on the far side of the hinge you can open the lid without removing anything also
    Also to prevent floating bags, if I know it’s going to fill with gas i’ll Double bag it with a bunch of spoons in the outer bag to keep it down
  11. #411
    Quote Originally Posted by ercchry View Post
    that's smart!
  12. #412
    Been using cheap amazon bags for smaller items from a company called Ronegye. Got 100 in 1 quart size and they have been flawless except I often need something a little bigger. Just picked up 100 in gallon size from same brand.
  13. #413
    Speaking of bags - shouldn't there be a little concern about the plastic chemicals leaching into the food with such prolonged exposure at an elevated temperature?
    (Sorry if this has been asked. It's a big thread and I'll admit I'm too lazy to look.)
    I'm not trying to be a hippie nut job, I'm just a little less comfortable with this compared to frozen food storage and storing leftovers in plastic, etc.
  14. #414
    Grimace
    I tried poached eggs yesterday, 167F for 12 min. Was not quite enough time seemingly as they came out OK but then immediately broke upon being touched. Will try again.
  15. #415
    I don't know. I've never heard of this being a concern, so I'll just continue not to worry about it. The low temps (usually under 150c) make it less concerning.
  16. #416
    Jun 2006
    As long as the bags you are using are food grade, you are fine. Food grade PE bags do not contain additives (or byproducts) which are known to migrate in significant quantities at elevated temps which would be harmful to ingestion, or to the waste stream. Now...if you are using knockoffs; they may not be food grade.
  17. #417
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    3 days in fridge salted
    1 day marinaded in kalbi sauce
    Now 3 days at 128.5F
  18. #418
    N/A
    And do you still have to finish them off in the barbeque/grill or do you eat them right out of the sous vide device?
    Will fuck off, again.
  19. #419
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    Quote Originally Posted by speedog View Post
    You can... but the texture and added visual of a nice char is worth the effort. So I will be giving them about 30-60 seconds/side over charcoal
  20. #420
    '14 Taco
    Well and you want the malliard reaction which you only get with finishing
  1. FS: Anova Sous Vide circulator (bluetooth)
    By Strider in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 01-12-2017, 10:10 PM
  2. FS computer parts..cpu..vide card..power supply etc
    By pinoyboy88 in forum Computer Hardware & Peripherals
    Latest Threads: 10-06-2010, 07:06 PM
  3. Vide Card Problems
    By project240 in forum Computers, Consoles, and other Electronics
    Latest Threads: 03-05-2005, 12:50 PM
  4. thinking of doing a max boost
    By redline in forum General Car/Bike Talk
    Latest Threads: 06-07-2002, 08:39 PM
