Sous Vide, who's doing it? - Page 22 - Beyond.ca - Car Forums
Page 22 of 34 FirstFirst ... 12 21 22 23 32 ... LastLast
Results 421 to 440 of 664
Thread: Sous Vide, who's doing it?
  1. #421
    V8s
    Trying out Sous Vide for the first time this week, doing some baby back ribs. Some googling produced the most common result of 155F for 24h.. I don't want to read 21 pages here, anyone care to validate this for me? Is it too hot/long or will that be alright?
    Also, finish on BBQ (nat gas), or broil in the oven for a couple mins?
  2. #422
    I’d use the oven to finish. More controlled results.
  3. #423
    '14 Taco
    Do you want them fall off bone, or with bite? 155 will have more bite, bumpnig to 160-165 will be more fall off.
  4. #424
    Calgary,AB
    I did 145 for 36 hours on my last go around....hardly had to chew
  5. #425
    V8s
    They went in last night, gonna have my wife turn up to 165 with 7hr remaining.
    edit: did 17h@155 then 7h@165, finished with convection broil for ~10min. They were absolutely perfect. Fell off the bone, but didn't turn to mush.
  6. #426
    Jun 2004
    21 CX5 GT Turbo
    Well and you want the malliard reaction which you only get with finishing
    I need to get more rolls of bags. Any suggestions on what works well?? Looking at Amazon there seems to be a few budget options compared to food saver
  7. #427
    I run the "roneguy" Amazon ones. No issues.
  8. #428
    Joining the ranks as I got one of these for Christmas. My friend helped out to get the cooler with the hole cut and everything. It seems like it'll be slick. I will maybe even put some foam/gasket material at the edge of the hole.
    Can the device rest on the bottom? I feel like I should choke it up a bit so it's slightly suspended.
  9. #429
    Slightly suspended is better because it is an impeller with an opening on the bottom.
  10. #430
    Nice. That cooler is better than my cambro tub. Device can touch the bottom, no problem. The heater element is inside.
    Edit, although I agree with killer that it's better for flow with a slight suspension. Just not a safety issue.
  11. #431
    Agree not unsafe, will just function better for circulation which in a body of water as large as a cooler is kindof important.
  12. #432
    Yes, I figured that. Its openings aren't literally on the bottom face, but the "sides of the bottom". I think I won't go balls deep in the name of Reynolds Number, diffusion equation, laminar flow, boundary layer thickness, etc.
  13. #433
    We can’t all be EIT’s
  14. #434
    I have the exact same cooler and hole. No need to seal it, probably some heat loss but don’t care, it holds 72C just fine, did a whole chicken in it yesterday. Works fine with it resting on the bottom, there’s more than enough circulation. I’ve made steak and wings meals for 12 with that setup with zero issues.
    The biggest thing it solves with the lid is water loss, which is non existent.
  15. #435
    ^I see that when digging a page back. Neat!
    Where should I start looking for recipes and basic shit? I got a few kg of frozen steaks already in vacuum sealed bags that I could try.
    I suppose I could drop them in while frozen and just have it take longer?
  16. #436
    Serious Eats is a good source.
  17. #437
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    I always go from frozen, time is pretty forgiving in there for most proteins, steak especially. Play with different times for the quality and cuts you’re working with
    Have come to the conclusion that sous vide adds nothing but a weird texture to chicken, most other proteins do benefit though, even seafood. Poached shellfish are great.
    If you go longer than ~6hr on any cook do consider weighing the protein down... or even just something that will not allow it to raise out of the water (fills the gap between water and lid) gasses will form and your vacuum pack will float eventually
  18. #438
    I find chicken gets quite misshapen in the bags which makes it tough to finish. Can’t argue with the results though it’s just not that pretty (150.1 is my favorite for chicken).
    I think steak and pork chops are my favorite sous vide meats.
  19. #439
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    Yeah, any skin on chicken is going to do a hell of a lot better on the bbq or in the oven, anything without skin is usually boring haha
    Short ribs or oxtail are the shit sous vide, give em a go, 36-72hr times, cooler w/lid highly recommend for that
  20. #440
    Women have some unholy fascination with boneless skinless chicken breast.
  1. FS: Anova Sous Vide circulator (bluetooth)
    By Strider in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 01-12-2017, 10:10 PM
  2. FS computer parts..cpu..vide card..power supply etc
    By pinoyboy88 in forum Computer Hardware & Peripherals
    Latest Threads: 10-06-2010, 07:06 PM
  3. Vide Card Problems
    By project240 in forum Computers, Consoles, and other Electronics
    Latest Threads: 03-05-2005, 12:50 PM
  4. thinking of doing a max boost
    By redline in forum General Car/Bike Talk
    Latest Threads: 06-07-2002, 08:39 PM
