Electrical advice needed. - Beyond.ca - Car Forums
Page 1 of 3 1 2 ... LastLast
Results 1 to 20 of 45
Thread: Electrical advice needed.
    Oct 2006
    Parked in Baygirl's garage.
    '21 F150 PowerBoost
    Default Electrical advice needed.
    So, I am looking to do some light welding in my garage, but, the way it is now with a couple heaters going, I keep tripping the 15A breaker before I even start welding.
    So, this is a 2 part question.
    1, can I just replace a 15a breaker with a 20a breaker, or is there a whole lot more prep work I gotta do...
    2, My garage has it's own sub panel, can I add a circuit on to that with a 20a breaker for the sole purpose of plugging in my 110v welder there?
    Any electrical gurus that want to offer some advice or even come take a look and discuss over a beer or two?
    Boosted life tip #329
    Girlfriends cost money
    Turbos cost money
    Both make whining noises
    Make the smart choice.
    Originally posted by Mibz
    Jul 2006
    FJR1300/2018 Giant Trance 3
    Apr 2006
    RSTi
    The breaker isn't there to protect the device, it's there to protect the wiring. By replacing the breaker you would exceed the maximum current draw in the existing wiring (14/2 I'm assuming) and that's not good.
    You still in Coventry? I could come and take a look and let you know what your options are.
    02 RSX
    if you have 14/2 (white) wire on 15amp, you cant not have 20amp breaker. You need 12/2 (yellow) wire for 20amp
    Apr 2004
    rs4, ram, 675f3
    The only answer is to add another circuit.
    Depending on the setup of your garage, it might be cheaper to run a portable heater off of some serious gauge cable from a plug off of another circuit.
    If you only weld occasionally in the winter, this would be more fiscally prudent than adding a whole other circuit.
    Oct 2006
    '21 F150 PowerBoost
    Yeah, I am still in Coventry, if you could swing by that would be great!
    It is all white wiring in the garage right now, however, the breakers in the house for the garage are 2x30a breakers, while the garage has 2x15a breakers. So I am guessing I could run a third 20a breaker with yellow wire to a dedicated plug for the welder?
    Turbos cost money
    Jan 2007
    NW
    06 F-150
    How many amps is the breaker for the sub panel? It could be located on the sub-panel, but would definitely have one on the main panel. Never put a higher amp breaker in. Just run a new circuit if it is right there. Easy stuff. Or PM me and I could throw it in for a good price.
    ^^^This. And don't think you're better than that code.
    Or physically turn off your furnace/heater before running the welder.
    Can't turn it off? Put in a shut off switch.
    Jan 2007
    NW
    06 F-150
    Correct. You would have no issues throwing in a new circuit.
    Apr 2004
    rs4, ram, 675f3
    Adding a 20amp cct providing you do the work is maybe 50-60$. Throw me a extra 100 ill come do it.
    Jan 2007
    NW
    06 F-150
    Damn recession got jmen working for apprentice rates! We don't stand a chance! Haha.
    Aug 2004
    Do you already have the welder ?
    If not look at getting a 240 VAC unit instead.
    if you are adding a circuit, might as well put in a good one.
    Edit:
    I re-read the OP...
    Guess you already have the welder.
    Assuming its a 120 VAC unit only...
    Throw in a 20 AMP cct and have at er...
    2011 Ram 1500 QC Sport
    2017 Jeep Cherokee Limited
    Oct 2006
    '21 F150 PowerBoost
    Edit:
    I re-read the OP...
    No, I am borrowing a friends for now, and I will probably buy one in the future, but running 220 out to the garage i don't think is something i am prepared to do, unless it would cost less than $20 more than adding this 20a breaker.
    Turbos cost money
    Sep 2012
    Shit for those rates can you come over to my house and put in some pot lights in the upstairs bathrooms?
    Jan 2007
    NW
    06 F-150
    Didn't you say there is a two pole breaker on your main panel for that garage panel? You already have 240 out there.
    Jan 2007
    NW
    06 F-150
    Haha pot lights and likely attic work costs more than easy garage wiring. Bet ya he won't do those so cheap. I wouldn't lol.
    Oct 2006
    '21 F150 PowerBoost
    This is why I am not an electrician. I really don't know what the fuck I am talking about when it comes to electrical.
    Turbos cost money
    Oct 2006
    '21 F150 PowerBoost
    This is what the panel in my house looks like, and the breakers for the garage....
    Turbos cost money
    Jan 2007
    NW
    06 F-150
    Haha. Post a pic of panel (the one in the house) and let us know what breakers are for the garage.
  1. Electrical help/advice needed
    By Speed_69 in forum Home and Garden
    Latest Threads: 10-05-2016, 05:15 PM
  2. Replies: 5
    Latest Threads: 05-22-2013, 08:08 PM
  3. Electrical Apprentices Needed Now!
    By dinglenuts in forum Careers
    Latest Threads: 08-05-2010, 04:34 PM
  4. LF: Electrical Design/Electrical Estimating work
    By Old Snake in forum Careers
    Latest Threads: 08-13-2009, 06:29 PM
  5. Home electrical help needed please.
    By variance in forum General
    Latest Threads: 01-03-2008, 02:51 PM
