i used envisalink in the past, it worked great, but only supports dsc and honeywell panels i think.
I use konnected, and tie it into home assistant. It's cheap, but very DIY/tech heavy.
Any chance you have tried to automate in a door chirp?This quote is hidden because you are ignoring this member. Show Quote
I’m trying to thread a needle on a request for the wife.
I use Honeywell. It’s tied to all my physical sensors.
I'm sure you can. I've setup automation to use the motion sensors to turn on certain lights after sunset, so if I run downstairs, a light automatically comes on and then shuts off after x amount of time. So you can 100% use konnected as triggers for anything that home assistant can tie into, including alarms, speakers, push notifications.This quote is hidden because you are ignoring this member. Show Quote
But it's all basically community support. I _like it_ because I like to tinker, but if you don't have the patience for it, I would 100% aim for something more off the shelf.
