I've had good results with my OBDlink lx. Only used it with the torque app though. http://www.obdlink.com/lxbt/
dv/dt
Ya you can buy these dongles from China for a few bucks. There's many apps that will work with them. Been around for years.
Bluetooth OBDII and Torque are two of the most common setups for phones and cars these days.
VCDS cables are cheap if you buy knockoffs. I got mine off kijiji for $70.
THE IMPORTANT THINGS IN LIFE:
N/A, 8000RPM REDLINE, CLOSE RATIO MANUAL, RWD, LSD
AE86, S2000, E46M3
Scratch that...fat, boost, AWD, DSG
Originally posted by adam c
Line goes up, line goes down, line does squiggly things and fucks Alberta"The stone age didn't end because we ran out of stones"
Bump for relevance
Sugarphreak, can obdeleven do module activation? I need to do some coding to add a Hitch to a Q5. I have been reading it does, but i want to double check before pulling the trigger.
