For sale: Used Hunter Tire Changer TC3500
In good working condition
Over $10k new
Sell for $2250 (Visa or MC add 8%)
email me if you're interested: [email protected]
Features:
Faster and easier to use than any other design.
Unlike conventional rim clamp mounting arms, there is no swing arm obstruction when servicing extremely wide wheels and tires.
No need to adjust the arm away from the wheel. The head follows rims without damage even when wheel is clamped off-center.
Exclusive polymer mount/demount head* removes the potential of steel-head-contact damage, rides closer than steel-head designs and reduces stress to beads on low-profile tires.
Force Multiplier helps with mounting and demounting low-profile tires.
Mechanical bead pusher is great for handling stiff, low-profile tires.
Spring-Loaded Wheel Centering Support
Work surface remains at consistent height regardless of rim width.
Exclusive Tulip Wheel Clamping System
Allows wheel to move in unison with hydraulic roller forces without risk of bending or damaging rim.
Eliminates steel-jaw clamping, which can damage the surface of exotic wheels.
Clamping arms, brake and motor are sealed against dirt, debris and moisture.
Eliminates traditional table designs that may act as a “launch pad” in case of tire failure.
All Functions Driven by Compressed Air
Reciprocating multi-piston air motor generates high torque and bi-directional 360° rotation, requires no electric hookup and is extremely quiet.
Variable speed operation up to 15 rpm in either direction.
Cover and rubber bellows seal the motor, brake assembly and clamping arms against dirt, debris and moisture.
Simple Two-Finger Controller
Air-over-hydraulic two-stage system allows fast positioning and operation of both upper and lower bead rollers.
Hunter Exclusive Hydraulic Roller System Aids Mounting, Demounting and Ultra-High-Performance Bead Loosening
Safely and easily handles ultra-low-profile tires, rim protection sidewalls, EMT Goodyear, Michelin and Bridgestone runflat designs.
Easily rolls the tire off or on the rim while reducing the potential for damage.
Tilted Ergonomic Design for Ease of Operation
Allows unobstructed lower bead access for lubricating before tire removal.
Complete operation, including bead loosening, can be performed from one position, saving time and physical energy. Requires no bending over for bead loosening.
Hunter Tire Changer TC3500 Specifications:
Clamping System Rotating Speed: 15 rpm (variable)
Recommended Air Supply**: 145 + 30 psi
Air Consumption: (approximately) 12 CFM
Wheel Clamping Wheel Diameter Range
Internal Clamping: 10"-24"
External Clamping: 9"-24"
Hydraulic Bead Loosening Roller System
Max. Bead Roller Opening Width: 19"
Diameter Range: 13"-24"
Bead Roller Power; Each Roller: 4,170 lbs. @ 140 psi
Bead Loosening Side Shovel [Optional]
Max. Bead Loosening Opening Width: 17"
Bead Loosening Power: 3,300 lbs. @ 140 psi
Shipping Weight: 560 lbs.
Max. Space Dimensions: Length 43" x Height 72" x Width 43"
