Originally posted by adam c
Line goes up, line goes down, line does squiggly things and fucks Alberta"The stone age didn't end because we ran out of stones"
I just had them in, great guy, awesome pricing but exclusively carrier. From what a couple people mentioned about that brand, I'm not so sure?Originally posted by nickyh
Same, used them on my last home and my current one. Can't say enough good things about these guys.
Thanks will do.Originally posted by Cos
Read that big thread, I know it is a bit of work but there is lots of expertise already written down.
Not sure if this helps you at all but here is my setup.Originally posted by imranm
I'm so confused by all this! I've had three quotes with all different specs. I'm in a 2700sqft dual zone setup.
I have one saying 4 ton, one 3.75, one 3.25.
Normally bigger is better, but I'm reading this is not the case with AC units.
Guess it's time to go with the gut?
Also some recommend 16 vs 13 seer... I'm inclined to go with 13 because it's Calgary, and we only really use it for 3 months a year.
Anyone with feedback?
Thanks!
2 Furnaces (1 upper floor), 1 for main floor/basement. Each floor is 1500sq ft. I have 2 x 2.5 ton units (13 seer).
I'm guessing you have 1 furnace? I'm not sure how dual zones work. When you got your quotes did they come to your house and take a look around? Based on windows/house direction/etc?
Similar setup. I have just one huge furnace that zones out based on need. When both zones are running it does take a bit longer, but thats how the builder did it!Originally posted by roopi
3.5 ton seems to be the way i am going. W&J killed the quotes, and although its a Carrier, with the 10 year warranty and their reputation I am pretty sure its going to be just fine!
Be sure to use one of the beyonder a on here as a referral so they can get a gift from W&J
