Garage Improvements - Page 12 - Beyond.ca - Car Forums
Page 12 of 25 FirstFirst ... 2 11 12 13 22 ... LastLast
Results 221 to 240 of 489
Thread: Garage Improvements
  1. #221
    Mar 2005
    2013 C63 AMG , 2022 Acura RDX A Spec, 2005 BMW M3
    Quote Originally Posted by GOnSHO View Post
    you just cut the plug ends off and attach to power in the sockets?
    I almost have the same setup, I just plugged mine into a smart switch so I can control mine from my apple home kit
    2013 C63 AMG Sedan
    2006 Nissan X-Trial
    2005 Bmw M3 vert
    2008 Ducati 848
    1977 Ford F150
  2. #222
    Oct 2007
    YEG
    Lotus and a Honda.
    Quote Originally Posted by navdeep View Post
    Do you have an ecobee running your furnace in there??
    Cereal Killer.
    @iambrianspilner
  3. #223
    Mar 2005
    Quote Originally Posted by B.Spilner View Post
    yup, i have 3 of them all together
    2013 C63 AMG Sedan
    2006 Nissan X-Trial
    2005 Bmw M3 vert
    2008 Ducati 848
    1977 Ford F150
  4. #224
    957,958,NC1,NC3,E90,ITR
    I have 32x of those Barrina LED's if anyone is interested. They are 2200 lm and 5000K so a bit different than what Amazon.ca sells. Will let them go for less than what Amazon is selling them for.
  5. #225
    Jul 2002
    Calgary/Phoenix
    2015 JGC SRT, 2011 Audi S5, MB CLS, 2015 HD RGS
    Quote Originally Posted by gpomp View Post
    PM'd you
  6. #226
    TRD Pro
    Damnit, I ordered a pack of 8 on the weekend.
  7. #227
    Sep 2005
    14' 435i
    Ordered 3 sets of those lights, mudded/sanded the whole garage this weekend! Paint and lights this week!
  8. #228
    Mar 2010
    Ioniq 5
    Gonna post this in here since it's not new thread worthy at this point.
    I'm looking at replacing my old single garage with a 22 wide x 32 deep garage in the next year or two mostly as I want a ton more workshop space. Recently I started floating the idea of a basement/storage area underneath the garage and it seems that pre-cast concrete spans aren't as intimidating as I originally thought (http://www.lafargeprecastedmonton.co...estern-canada/) and its looking fairly feasible to do.
    Wondering if anyone know anyones thats done a storage area under their garage and might have some advice.
    I'm assuming I'll need:
    A) A pinky ringer to stamp the design
    B) A lot more excavation costs
    C) A fair bit more expensive foundation / concrete costs
    D) The beam/span structure however its designed (+1 day of a crane to move them into place)
    E) A 2-3" slab poured on the span
    F) Regular garage building after that?
    Assuming we're talking .... ~20-25k extra on top of a regular garage pad cost?
    The plan was to DIY the build after the concrete step as me and my dad have built a number of buildings before, trying to figure out how to go about this. Would I need to seek out a niche concrete company or is this somewhat common give that it's similar to a house having a basement poured anyways.
  9. #229
    Sep 2008
    NE
    Ram 1500, '68 Camaro, S14
    Also consider location of utilities, if you’re going from a single to something that big you may need to relocate your gas line? I had to relocate mine to build.
  10. #230
    Stampede Central
    is pretty sharp lookin'
    probably easier to permit going up a storey...
    much easier to design IMO
    But my pinky-ring ass has never designed/stamped anything in my career and now it's kinda a life goal to live this way
  11. #231
    Sep 2008
    NE
    honestly probably way cheaper, forming/pouring/finishing will be your biggest cost.
  12. #232
    WHY NOT BOTH!!?!?!??!?!!!!! Basement and 2nd story in garage! I support this.
  13. #233
    ^P.Eng approval obtained^
  14. #234
    V8s
    IIRC permitting a tall garage is not easy. Basement would be nice, but also poses it's fair share of challenges too.
    Tbh, the bigger footprint is going to provide more useable space and will be easiest from a construction perspective. I wouldn't want to have to have a workshop up/downstairs either.
  15. #235
    Jun 2007
    ATS, XC90
    Also want to consider different drainage, or whether you might want an opening between the spaces, like they have at a quick-lube places. Would save you from ever having to get a lift, but also introduce a host of other issues.
  16. #236
    Mar 2010
    Ioniq 5
    Basement would be preferred just because of the location, a two storey would block most of the sun from the yard and isn't appealing along with it being a neighborhood of bungalows.
    Utilities shouldn't be any different. There's overhead power in the alley so either way I'd be relocating my meter to the garage with a new 200A panel and then running the house as a sub. There's no gas line to the garage currently so same same cost with or without the lower floor id presume. Maybe a bit more expensive if the line needs to be larger for sufficient heat.
    I'd want a staircase down to the bottom along a side wall, not any kind of mechanic pit though. I hadnt really considered drainage as an issue, I'd assume sloping the main garage towards the big door and away from the stairs would suffice.
  17. #237
    Bunch of Honda's
    You will soon learn that a structural slab is significantly more expensive then a rinky-dink residential slab on grade. You're also going to want a real traffic coating or membrane or else you'll have moisture issues in your basement. You also need to insulate the slab which is a huge pain in the ass.
  18. #238
    Sep 2008
    NE
    you cant build over the gas line though, so would need to relocated your meter(pay atco)/main line in if it ends up beneath the new foot print. should be easy to tell if its an issue by the location of the meter though.
  19. #239
    V8s
    This is an accurate, but not exhaustive, list of the issues with adding a basement to the garage. I think of the three, this will be the most cost prohibitive option by a large margin.
  20. #240
    May 2004
    Ford, Acura
    Put in storage attic trusses and be done with it. 8' wide by 32' long is an extra 256 sqft of storage, if you fill that up on top of storage you have in your house then you have way too much shit. That was easily the best thing I did in the last garage I built.
    I'm generally cute.
  1. Some Home Improvements & DIY
    By bobby_lu in forum Real Estate / Finance
    Latest Threads: 08-02-2007, 03:31 PM
  2. Market place improvements
    By Forkster in forum Suggestion/Comment Box/Forum Related Stuff
    Latest Threads: 03-12-2007, 06:55 PM
  3. Deerfoot / Beddington Improvements
    By Dren in forum Society / Law / Current Events / Politics
    Latest Threads: 05-26-2006, 12:05 PM
  4. Secret Street and AutoX Changes/Improvements
    By rage2 in forum General Car/Bike Talk
    Latest Threads: 12-31-2004, 09:08 PM
