Minimum height above finished flooring for window on upper level - Beyond.ca - Car Forums
Results 1 to 16 of 16
Thread: Minimum height above finished flooring for window on upper level
    Feb 2003
    DT 780
    LEXUS LX470
    Default Minimum height above finished flooring for window on upper level
    Hi All,
    I am trying to get some info on the building code but finding it quite difficult. I think there might be a copy at the local law library but not too sure so I thought I'd see if anyone here happens to know.
    I am wondering what the minimum height above the floor is for a window on the second level of a residential home. I see that in the US this height is typically 18". Is this the same for Canada? The window would be 30" wide and hoping to have it 84" high, but would possibly need safety glass to meet code.
    Let me know! Thanks!
    Tap, Rack, BANG!
    Dec 2008
    A semi-detached home from 89Coupe (hahahaha)
    A Gallardo from SDS (hahahaha)
    Default Re: Minimum height above finished flooring for window on upper level
    Originally posted by littledan
    Hi All,
    I've seen homes with floor to ceiling windows on the second level, so based on that, my guess is that there is no minimum.
    Jan 2016
    The YYC
    Parked in the Bike Lane
    Default Re: Re: Minimum height above finished flooring for window on upper level
    Yep, a few downtown condos have that. But they probably have to meet some standard for glass type or shatter resistance.
    Sep 2002
    Beyonds Official Realtor
    www.jordanlotoski.com
    I don't think there is a minimum Height..My windows sit right on my floor on my main level and upper level, they are commercial windows.... I have seen residential windows no more then 6 inches off the floor.
    "BEYONDS OFFICIAL REALTOR"
    Instagram @jordan_empirewest
    Ranked #1 RE/MAX Professionals (2013-2022)
    Ranked Top 100 Re/Max agent Western Canada (2013-2021)
    Check out my mobile app
    goagent.ca/98F1B2F9
    Feb 2003
    DT 780
    LEXUS LX470
    ok right on thanks guys. I will talk to my builder and see if I can get a hold of the actual code to confirm.
    Tap, Rack, BANG!
    Aug 2008
    TDi
    I was told, from my builder, that they had to revise a few windows upstairs. They were maybe 6 inches from the floor. They had to make them a bit smaller so they weren't so low?
    Something to do with kids safety?
    GO FLAMES GO!
    The SHBARUS
    Since there is fall hazard, floor to ceiling glass just like any other wall construction, should be designed as wall acting as guard. The major difference is the nature of glass. Unlike most other material, a small flaw in glass can jeopardize the integrity of the entire piece. The current building code doesn't address this issue very well since glass is not a common structural building material.
    Long story short, there are a lot of questionable things out there. If you want to do it right, this is getting into specialty design, not something that you can get from your local hardware store. It can be done right.
    The SHBARUS
    You may find information on wall acting as guard but you won't find much information regarding building a wall with glass in the actual building code. It will refer you to a different document, aka Structural Design of Glass for Buildings. Like I said, specialty stuff. This is not cookie cutter design if done properly.
    Mar 2009
    Edmonton
    for traditional windows, no curtain wall or anything, be cognisant of the height of your baseboard and casing to ensure no issues.
    Ie. if your baseboard is 5 inch and your window casing is 3 inch, you should be atleast 8.5 - 9 inch above floor.
    The SHBARUS
    Your typical window manufacturer can't give you windows that are designed to act as guard so you can't put them anywhere guard is required. Minimum guard height for dwelling units is 900mm from finished floor. For cookie cutter design, that's as low as a window can go. Will the building official catch that? I can't say for sure but that's the building code. Otherwise design your glass to act as guard then you can put it as low as the floor.
    Are there city bylaws pertaining to adding windows to a house Calgary?
    The SHBARUS
    If I have to guess, there probably is a limit to the size and number of windows in between houses for fire spread control. What do I know, it will probably burn anyway.
    Bunch of Honda's
    There are no city bylaws that pertain to window sizes or locations or spread of fire (as noted in the post below yours). There a development and building permit approval processes that need to be followed to add additional windows though yes. And you would need to comply to the applicable Alberta or National Building Codes, they do specify all those fun details about fire spread, etc.
    In a private, single family home there are no restrictions to guard heights for window sills that I'm aware of. There are however guidelines for the amount operable windows can open below a certain height. This is to stop a small child from falling through a window screen (which has happened before).
    May 2003
    1988 Accord, 1990 4Runner SR5
    There are also bylaw restrictions on windows which overlook a neighbouring property, and these have guidelines on how high the window must be above the floor, otherwise it will need to have obscured (ie: frosted) glass if it does overlook the neighbours. This mostly pertains the infill properties, but does exist.
    Aug 2002
    992 T-hawk Golf R
    I thought this was the case as well. I didn't think you were allowed to have windows in line with a neighbors window. (next door neighbor, not across the street)
    I like neat cars.
    Our house (build it 1979) has an original bedroom, narrow, picture window (floor to ceiling) that faces our next door neighbours, original, bathroom window.
    No curtains on theirs, so we frosted ours.
  1. Rebuilding an HTPC as mid/upper level workstation
    By Super_Geo in forum Computers, Consoles, and other Electronics
    Latest Threads: 10-01-2015, 06:59 PM
  2. LF: Half Height Computer Rack & FS: Full Height Rack
    By SportTwin in forum Computer Hardware & Peripherals
    Latest Threads: 06-21-2012, 09:47 PM
  3. Replies: 8
    Latest Threads: 08-03-2010, 01:00 PM
  4. Minimum lift height on 95 ZJ (grand cherk) to clear 32x10.5 tires
    By zipdoa in forum Trucks, 4x4 and Offroading Zone
    Latest Threads: 01-31-2009, 01:56 PM
  5. For Rent: 3 Bedroom House Upper Level and 2 bedroom Lower Level
    By Weapon_R in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 11-16-2006, 11:29 AM
