Originally Posted by
Kijho
Oooh that might be a PITA I forgot some open sideways LOL.. upwards opening is much easier and you just add like 6" extra slack in the wire. Swing opening door.. you might be able to run the wire along the top of the window there and have just enough slack at the hinge, secure the wires there with clips so they can't get pinched maybe. I'd run it that way, so across the window (might not be anywhere to hide it but possible in the crevice of the window and the panels) then some wire might be exposed there, down the side of the door and the hinge.
OR you can go all out and be like Benyl, remove all your panels, run the wire through the OEM looms and grommets in the door hinges, I don't think I could help on that method hahaha that's gonna be alot of work.
