Yamaha is sold.. Pitster still for sale.
Beyond Price: $900.00
The bike runs and drives awsome, fun little starter bike, slightly smaller than a full size jap bike but much bigger than a mini bike.
Brand new front tire and rim
Wind Guards on handle bars
metal mulisha fat bars
new clutch and brake levers
electric start
ENGINE
Engine type: Water-cooled; 248cc, 2Valve
Displacement: 248cc
Bore: 66mm / 59mm
Compression ratio: 10.8 : 1
Starter: Electric & Kick Start / 7amp battery
Transmission: 1-0-2-3-4-5 Gears
Carburetor: Mikuni
Engine Lubrication: Pressure Pump Feed
Chain Ratio: 14T / 38T
Final Drive: 2.7 : 1 520 Chain
Cooling: Water Coolant
Clutch: Wet Clutch
Ignition: CDI Electronic
CHASSIS
Frame: Chrome Molly
Subframe: Chrome Molly
Handlebar: "Fat Bars" / 28mm - 22mm
Front Suspension: Front Suspension: SPX Race Forks Preload & Compression adj.
Rear Suspension: CAM Link Rear Suspension, DNM Shock Preload, Compression & Spring Adj.
Suspension Travel Front / Rear: 250mm Front / 240mm Rear
Brakes, Front / Rear: SS Hydraulic disk / No asbestos
Tires, Front / Rear: MX Tyres ,18" rear ,21" Front
Chain: 528
Main Silencer: Glass filled Sport Stingger
Wheel Base: Wheel Base 1505mm
Ground Clearance (unloaded): 280mm
Seat Height: Normal 925mm / Lower link 860mm
Fuel Capacity: 8.6L
Weight (no fuel): 114 kg
http://www.kijiji.ca/v-dirt-bikes-mo...ationFlag=true
